Question about Karcher WV50 Window Vacuum
The switch will not hold on, it runs for a few seconds then stops. Will start again but stops.
The unit is fully charged, sorry, appeared fully charged. It now makes sense that it was not holding a charge. The symptoms are the same as when it needs charging.
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
IRobot will stop after few seconds ..
How old is the unit? It looks like the battery needs to be replaced.
Feb 24, 2008 | iRobot 4296 Robotic Vacuum
It runs for a few seconds and cuts off.
Hi Robert,
Thank you for reaching out. I am sorry to hear you are having difficulty with your DC31. Based on the details you provided we would like walk through a few trouble shooting steps and we may be able to resolve this right over the phone.
At your convenience please call our Helpline to speak with an expert.
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Dec 20, 2013 | Dyson DC31 Bagless Handheld Vacuum
I have a 4.5 year old IRobot Roomba 530 Robotic Vacuum. Appears to be fully charged but then only runs for about 30 seconds before stopping. What may be the problem?
You need a new battery - they don't hold their charge after a while. There is a lot of advice on line about how to try to make the battery last longer but 4.5 years is actually pretty good.
Sep 02, 2013 | iRobot Roomba 530 Robotic Vacuum
Just put a new battery in scuba and it runs about 30 seconds (completely charged)
1) replace again the batteries by new ones and completely charged.
2) test the charger if if functioning properly, can be faulty, and not charge well the batteries.
3) test the power supplies inside from the scuba, to due some short circuit drain the batteries.
God bless you
Sep 19, 2012 | iRobot 5800 Scooba Vacuum
I have a Eureka Easyclean that will not hold a charge and want to replace the Electrolux battery it comes with and cannot find one. Can you?
Sadly, the battery is not replaceable on this unit. According to the schematic, I can get almost every part but that. This is common with all of the cordless units too. Batteries are usually the same price as purchasing a new unit. If the unit is more than 1 year old, sorry to say its pretty much garbage. IF the unit is less than one year, it should be under warranty and replaced by your local Eureka/Electrolux dealer.
Also, not all hope is lost on this unit, if there is an obvious burn, or connection issue, a little bit of solder should correct the problem.
Good luck!!
Jan 24, 2012 | Eureka 109A Easy Clean 2IN1 Cordless Stick...
My fully charged Roomba 560 just moves a few inches, cleans spins in a circle then stops and a red exclamation point appears. (I've misplaced the manual help !
You have dead nimh (nickle metal hydride) batteries
You will need a replacement. You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new.
Feb 26, 2010 | iRobot Roomba 560 Robotic Vacuum
IRobot 530 charges intermittently
Reset the Roomba: hold down "spot" and "dock/demo" for fifteen seconds, then release and listen for the tune. Then charge the Roomba overnight. The next time you run it, the unit should run longer. If not, call support and let them know you may have a battery problem. 1-877-855-8593 (I strongly encourage you to have the Roomba with you if you call.)
Aug 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Keeps stopping.
your battery isn't holding a charge ,buy a new battery
Mar 25, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Karcher WV50 Window Vacuum Logo
410 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
