Question about Hitachi 50VS810 Television
I just replaced the lamp in the tv but now the fan light is flashing.can't get at it.
    Top Expert:
  • Hitachi Master
  • 75,462 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Apr 07, 2015
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
Had check fan no 2 on tv. I replaced. The bulb is about 6 months old as well. I power on both fans are working the bulb comes on but the tv shuts off after a few seconds before the picture even comes on....
U recheck the tv projection lamp connections,the door latch and the lamp door closed properly and tightly.Yes,if the tv projection lamp LED light indication "LAMP" word it is still flashing or staying on the tv projection lamp some how dying again.The tv projection lamp should be replacing it again.
Sep 02, 2011 | Samsung HL-S6188W 61" HDTV
Fan motor is macking nosie and the lamp light on front panal is flashing
Buy a new fan and replace it.Tries websites like Partstore.com,Ebay.com to buy a new fan for the replacement.Tv should be working again,if tv still have LED "LAMP" light indication still flashing.The tv projection lamp life are over.Replace the tv projection lamp too.
Apr 03, 2011 | Mitsubishi WD-65731 65" HDTV
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
Power keeps flashing red. We have cleaned fans and this has helped in the past but I can hear the small fan come on and the larger one by the lamp is not. How can I repair this?
The"LAMP" LED light indication flashes also and the projection lamp been inside the tv like 1/2 or 2 years,tv been on and used like 4 or 5 hours daily?The tv projection lamp life are ending.Should get the tv projection lamp replaced.
Dec 17, 2010 | Sony KDF-50E2000 50" HDTV
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
Replaced color wheel and the lamp...tv still. Cycles on and off..with "lamp" green light flashing along with standby light flashing...nothing on screen and lamp not coming on? Its an hlp5063w. Please...
Since you have replaced the lamp and wheel, next would be the ballast and power supply board. These provide power to the lamp and Samsung recommends replacing both at the same time. If power supply board is bad, it can destroy the ballast so replace both. This usually takes care of the problem.
Aug 06, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Four blinking lights from standby led lamp after I turned on the TV.
Yeah, it is not lamp problem. Check fans in tv as one of fan is stopped for some reason and causing problem.
Jun 29, 2010 | Sony KDS-R50XBR1 50" HDTV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Aug 14, 2009 | LG RU-44SZ51D 44" Rear Projection...
Open Questions:
See all Hitachi 50VS810 Television Questions
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
