Question about Roper Dryers
Roper elecrtic dryer will only turn on when the selector is on auto dry less heat or on timed dry low heat and never has any heat, any help
  • Roper Master
  • 5,323 Answers
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Posted on Apr 13, 2015
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
Dec 17, 2014 | Roper Dryers
Dryer runs but doesn't heat.
The high and Low thermostatic limit switches must be in working order for the heating element to get power to operate. High limit opens in the event of a overheat condition to cut off the heating element. The low limit cuts on and off to control normal operation of the heating element for a more or less constant heat for drying.
Mar 18, 2014 | Kenmore Elite HE4 Electric Dryer
My roper gas dryer seems to be getting heat (not very hot) but isn't drying clothes. the selector nob only turns under timed dry.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 23, 2011 | Roper RGX4634KQ Gas Dryer
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Warm heat..clothes not drying
john there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house venting.you .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Jan 01, 2009 | Roper REX3614KW Electric Dryer
Roper Dryer not Drying
Get a thermostat and place it in the exhaust. The thermostat should reach 160 and then shut down and drop to 120 F and start back heating to 160 again on cotton setting. You should hear an audible click when the thermostat opens and closes. If the dryer is clear of lint and blockages then change the control thermostat which is mounted on the blower housing.
Sep 07, 2008 | Roper REX3614KW Electric Dryer
Dryers Logo
87 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
