Question about Whirlpool Dishwashers
The motor is running but not getting any water
    Scholar:
    New Friend:
  • 123 Answers
Water not filling.......
1. Did you check the house water line to dishwasher is not shut off. Check under your sink.
2. If that is okay then either your machine water valve is faulty or your machine water level switch is faulty. As a first step give a tap or two to the water level switch to release it.
Posted on Apr 25, 2015
Motor runs good out of water in water no go
quite possibly you need a water pump.
Jul 01, 2014 | Nitro Boating
Ice maker runs continuosly but no water is in the cube tray
It could be the valve. If it does not let water in, it will try to make ice and none forms so the motor keeps turning waiting for ice to form.
If the motor is turning its fine. Concentrate on how the water reaches the tray, its probably not getting there.
Dec 22, 2013 | Whirlpool Refrigerators
Fridgeair dishwasher not working making loud sound. water comes in and I can make it drain out but washer does not start
Hello
bearings in the heater fan may get worn out or rust. If this happens, it may become very noisy, either grinding on the bearings, or scraping against the rust. If this happens you need to replace the fan motor. Sometimes, a fan blade may come loose, and you need to replace it.
Sometimes it's the motor that makes the noise you hear. The motor has bearings in it which may become worn or get rusty. When the bearings get worn, they allow the shaft to wobble which can get quite loud. If there is a spin seal leak, water may get inside the motor, washing the bearing grease away. If the spin seal is leaking, you'll notice water leaking from under the dishwasher. There is also a disc attached to the top of the motor called a slinger. It sometimes breaks off and spins around the motor's shaft while it turns, causing some noises. You will need to replace the motor if the bearings are bad. You also need to replace the motor if the slinger is broken as well.
Newer dishwashers may make a squealing or rattling noise on the first run. This is because it has not had any water in it yet, and the motor seals are dry. You may hear this in a unit that hasn't been run in a week or more as well. You should operate the dishwasher regularly to keep the sump water from getting smelly, and to keep the seals lubricated. You can add a quart of water to the sump before running it.
Rattling noises may be produced by dishes rattling inside the dishwasher due to the water pressure from the sprayer arms on the dishes. To determine if the rattling is a loading issue, run the unit empty. If the sound is persistent, it may be that there is debris in the pump.
dishwasher water-inlet valves are noted to make a hum that lasts about 60-90 seconds several times during a washing cycle. This hum is a different hum than the sound of the motor running.
A rhythmic knocking or thumping sound may be caused the sprayer arms hitting something as they go around and around. Rearrange the dishes and resume the wash.
A clunking or clanking may be heard when the detergent cup opens; while a clicking sound may be produced by the timer or electronic control panel.
A solenoid makes a snap sound when it opens. This happens about six times during each load.
Pipes rattling or banging may be caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The sound is caused by the water slamming into the closed section of pipe. A plumber can install an anti-hammer device.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and then remove the item that is making the noise or replace the pump. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher.
Send this page to your printer
Aug 06, 2011 | Dishwashers
Water spay is really hot from the motor? cuts out after a short run. it gets that hot it steams. you can only get 500 meters then it cuts out? please help
Sounds like either your water pump is worn out, water intakes are clogged, or something is blocking the water passages in the motor. Just because you have water spray coming out from the motor, it does not mean that the motor is getting adequate cooling. In any case, you should take it to a motor repair shop and get it checked. If you keep running it hot you will probably ruin the motor.
Apr 28, 2010 | Boating
Asko D1706.The washing arms have stopped turning.
Can you hear the motor running? If the motor is runningand machine is full of water, but not pumping water around, you have one of the following problems:
-a blockage in the filters or sump preventing enough water getting to motor impellor,
-blocked jets in spray arms themselves,
-or I have had cases where the impellor has broken off the motor, hence motor runs but doesn't pump any water around. Check for blockages first, wouldn't suggest you take motor out and disassemble unless qualified or confident to do so (it's not an easy job if you haven' done it before!!)
Aug 04, 2009 | Dishwashers
LAVAMAT MOTOR DOES NOT RUN
If there is water getting into the machine, then the motor, motor control unit, pressure switch, timer control and wiring harness must be tested. If the machine is a top load the motor coupler may replace the MCU of variable speed motors, that must also be tested then.
If cycle is not operating at all, with no water getting through the inlet check lid switch, door latch, inlet hose , inlet valve, membrane switch, Timer board and MCU if present.
Aug 02, 2009 | AEG Washing Machines
Washers not working on ford focus
check the motor or hose probable clog. hope this help
Dec 17, 2008 | 2001 Ford Focus
Our dishwasher is not running through all cylcles
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Dec 02, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dishwashers Logo
83 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
