Question about Yuan Tai Montgomery Queen Platform Bed Collection
The slates to my bed just came out of the plastic brackets, I need to know how to put them back without breaking down the entire bed. Help and just as and FYI no undo stress was put on the bed
Turning on hp slate 500 without power switch
I hope you found a solution months ago, but just in case:
My switch also broke a while back, and this is a common problem with the slate 500 due to the construction of the switch.
This should help:
http://forum.tabletpcreview.com/hp-slate/41309-my-power-switch-just-broke-2.html
My solution: remove what's left of the plastic switch (if anything) then use a long thin thing (LTT) (about 2 cm long) in the hole where the switch was. I use a squashed paper clip - someone else had a mini screwdriver, someone else the toothpick on their pen knife.
Put the LTT straight at the top of the switch hole and pull down, the same way you used to pull down on the power switch, then let go. The indicator light under the switch hole will blink 3 times quickly if you've successfully tripped the switch.
All the best!
Nov 05, 2012 | HP Slate 500 8.9 Tablet
Change brake light bulb on a 2000 Nissan Frontier
The entire bed line will need to be removed. The long screws that hold the metal bracet where the bed extender attaches also hold the tail light assembly in place.
I pulled the bed liner up at a 45 degree angle and layed it on top of the cab. This revealed the screws. Take both screws out and lay to the side along with the metal bracket for the bed extender.
Now firmly grab the edges of the tail light assembly and pull...there are 2 hard rubber nipples that snap in to hold the assembly. You will feel like you might break it but you won't..just pull straight back hard. The assembly will "POP" out and then you can just twist the back of each bulb there are (3) and pull out..now you will see the bulbs..just pull the bad bulb straight out and push the new one into place. Now just reassemble. Total time will be 30-45 min. for this repair.
Mar 30, 2010 | 2000 Nissan Frontier
Replacing front headlight bulb . Instructions for
With the hood open, you will see a long flat flexible plastic cover running across the front, above the headlights. It is riveted in with plastic rivets. Hold the outer part of the rivet, and pull up the center part. Then remove the whole rivet. Remove the plastic cover. (When you put it back on, insert the outer part in the hole, then press the center part down into each rivet.)
You will see a sidelamp and headlight assembly. Look down between the sidelamp and headlight, there should be a black plastic clip or latch that holds the side lamp to the headlight. (The clip is down a hole, in the bracket holding the headlight to the body). You will probably need a long screw drive to get down in the hole to release the clip. And maybe a flash light to see down the hole. Put just enough pressure to release the latch, it is plastic, and if you press to hard it could break. Once released the side lamp will pop forward a bit. The sidelamp section can be pulled forward. a bit. However, there is a long plastic part on the Sidelamp Section that slides into a metal hole in the Fender. It will break if you try to pry the sidelamp section out sideways.
Next you will see two top-mounted bolts holding the Headlight Assembly in place which can easily be accessed and removed. Removing the bolts will loosen the entire headlight assembly.
Some instruction say you can remove the headlight and side assembly as a unit. Do not do this! If you try to remove the headlight assembly without detaching the sidelamp you could break either of the lights or the connection assembly.
The Bulb Assembly twists out of the back of the Headlight Assembly, and the bulb can then be replaced. Be careful not to touch the bulb with your hands or with any grease.
Many of the parts are plastic and can break, so do this carefully and patiently. It sounds a little complicated, but once you learn how, the whole job only takes about 20 minutes.
Hope helped. (remember rated this).
Oct 19, 2009 | 2002 Chevrolet Cavalier Coupe
My choke won't stay out when i pull it out. Is there an adjustment i can do? or do i need to replace it?
you can loosen the nut on the back side of the bracket the holds the choke knob and then turn the piece on the front side of the bracket clockwise. This will put more tension on the rod. BE VERY CAREFUL.....this is plastic and it won't take much to break it. gently tighten the nut on the back side of the bracket....not much more than finger tight as it will break the plastic housing also.
Jun 05, 2009 | 2001 Harley Davidson XL 1200 C Sportster...
Unable to scroll down - txt messaging
well my pantech slate was doing the same thing, so what i did was turn off the phone, take the battery out and put it back in.
after i turned it on, it was fixed. voila.
Jun 01, 2009 | Pantech Slate Cell Phone
The 4 plastic brackets that adjust the bed spring up or down have broken, can these be replaced and where do i find the replacement parts. thanks for any help
You can email them - they emailed me the instructions and parts list in a 16 page pdf.
customerservice@sjfdec.com
Here are the instructions for your crib. Please review them and see which parts you will need. We accept Visa or Master Card. Parts are non returnable. Delivery is normally 7-10 business days. We do have replacement parts for this crib. Please review the instructions and see what you will need. J Thank you, CindyCustomer Service RepSimmons Juvenile Furniture':Phone: 1-800-218-2741 ':Phone: 1-920-779-40047:Fax: 1-920-779-4216
May 23, 2009 | Simmons Mattress Matino - Natural Maple...
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Side rails
I have a similar problem, but a different Simmons crib. I called the company that momof4girls unrecommended and they were VERY helpful, but they were not able to ship me the parts as Simmons discontinued this type of hardware in the early 90's. My crib has a headboard and footboard - the 2 side boards are able to slide up and down on aluminum slats (almost 3 feet long.) The aluminum slats are connected to the headboards with 8 bolts; what I needed to order replacements of are the plastic sliders that allow the sidewalls to go up and down on the aluminum bracket. Not only do they allow it to go up and down, but without them you are not able to assemble the sidewalls to the crib at all. I solved the issue buy purchasing L brackets at Lowes and permanently attaching the sidewalls to the headboard and footboard, but it made it so the sidewalls did not raise or lower. I am ok with that! However, if you do NOT have the aluminum slats, you may be out of luck. The spring for the bed attaches on the aluminum brackets, so even if you were able to bolt the 4 sides together, you still have to figure out a way to attach the spring for the mattress (which connects by sliding a hook into holes on the aluminum bracket... no room for bolts here.) I am rather surprised that the hardware for this crib is plastic and aluminum; the bed is HEAVY and it is very difficult to put together as the aluminum slider is easily bent and the plastic sliders are flimsy. I actually broke the plastic pieces during assembly. No wonder this hardware was discontinued! I called Simmons and asked if they had an "updating' kit... they do not. Good luck!
Aug 25, 2008 | Bassett Baby Gear
VS 50605 screen replaced
first of all wally heres what to look for. remove speaker grill not sure of your model. speaker grill should pop off. then you will see screws holding the large plastic screen assembly. noww if you look there might be a group of wires going up to screen,they will be atatched to small plugs unplug them, remove small screws on bottom of screen assembly, entire plastic screen assembly will first slide up then pull away put assembly flat on floor (don't scratch screen put on carpit or sort surface ) screen side down. all around plastic screen you will see brackets with screws holding them on remove top,bottom,side bracket carefully put screen back in making sure the front side of screen is down replace brackets if plastic is not damaged should screen in place.reverse order of removal. remember alittle up then screen will slide down in groves doc
Aug 13, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Yuan Tai Montgomery Queen Platform Bed Collection Logo
320 people viewed this question
Top Yuan Tai Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Yuan Tai Furniture Expert? Answer questions, earn points and help others
