Machine filled with water then stopped running
  • 1,511 Answers
Jhonny Rendon gave the best answers and he is knowledgeable.
Posted on Apr 16, 2015
  • Washing Mach... Master
  • 5,323 Answers
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
4 Suggested Answers
  • 289 Answers
SOURCE: My washer machine is filling up with water but will not stop
hi..the problem may be due to two reasons.
one is your washing machine will not be fully
automatic,it may be semi-automatic.In that case
the water will not stop automatically after reaching
its capacity.other problem may be there will be some
short in the wire in an fully automatic machine which
could have lead to this problem.
check it out.
thank u.. rate me..
Posted on Feb 05, 2009
  • 64 Answers
SOURCE: Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
Posted on Mar 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: I run my washing machine. It won't stop running
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^&
Posted on Sep 29, 2010
Washing machine stopping and starting when filling
Sounds like maybe a bad water inlet valve? timer may have isses as well? have u tried running it in hot water only and cold water only cycle? see if one line is bad in ur inlet valve?
Dec 16, 2014 | Washing Machines
My washer want stop filling up and when I should the machine off the water runs in the floor
Good Afternoon Friend,
I understand that your Frigidaire washer, model# FWS833A, will not stop filling. I see that you shut the machine off and the water runs onto the floor. I suggest shutting the water off at the inlet. From there I would contact your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water will not stop filling your washer. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire FWS833A Top Load Washer
Water sensor
common faults include the rubber pressure hose rubbing and a hole forming causing the pressure switch not to recognise the water level. un plug the appliance, take the top off, find the pressure switch and you will see a rubber black or clear hose running from what is normally a circular item approx 2" diameter and a hose running doen to the drum, check this hose for splits or tears.
Apr 10, 2014 | Washing Machines
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
Washer is overflowing
The water input on washers is controlled by the timer which actuates the solenoid valves for both hot and cold water, telling them when to fill and when to close. I would run the machine thru a fill cycle with the washer back off, and with a voltmeter, observe if the voltage ever cuts off as the timer runs. I Another variable is the water level control. So also determine if that is working since if it failed to open the 'fill' circuit at the proper volume, you might have this overflow problem.
Aug 15, 2011 | Maytag Washing Machines
I have a Whirlpool washer. It will fill and run through the first cycle and then stop... What would cause this?
I would pretty much guess it's a faulty heating element. After the machine stops after filling with water and running a while to get the clothes wetit stops to heat the water. Listen carefully to hear the water heating up, it sound simular to an electric kettle. If this does not happen the program is unable to advance.
Apr 06, 2011 | Whirlpool Washing Machines
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
Machine does not stop filling with water. Will
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 30, 2009 | Washing Machines
My washer will not stop filling with water and overflows
Turn the washer on and let the water run, while the water is running unplug the power cord if the water stops the inlet valve is ok but if still running the valve is bad and need to be replace if the pump is good you need to test the water level switch, if faulty need to replace.
good luck
Mar 17, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
