Question about Sewing Machines
Delta OL-1000 Overlocker. It worked fine for a short time, then went wrong. It won't create a stitch. All I get is straight lengths of cotton. I am still using the original reels of thread supplied.
Delta OL-1000 overlocker
    Master:
  • Sewing Machines Master
  • 470 Answers
Is it still in warranty? Take in the the place where you bought it.
Posted on Apr 08, 2015
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
How do I get the stitch length to be consistent? It changes with speed
consistent stitch length depends primarily on tension settings. there are 2 different tension settings on all machines. 1. upper thread tension. 2. bobbin thread tension. since these work together to create the correct stitch length+width, having either of these adjusted inappropriately can significantly impair stitch quality. "knowing' your machine has a lot to do with knowing how tight or loose the tension should be for BOTH settings. the settings will be different for each type of stitch, for each type of needle used, and for each type of thread used, meaning tensions will need to be re-adjusted after each change. in other words, the setting for a medium-width zig-zag with a size 10 needle using mercerized cotton thread to sew light-weight canvas will be completely different than the settings for a regular straight stitch using a size 8 ball tip needle using polyester thread to sew silky lingerie material.
Jun 14, 2014 | Brother PC-420
Delta ol 1000 overlocker sewingmachine
check with a1sewingmachines.com or sewvacdoctor.com and call them or email them about the parts you need
or check ebay
Sep 25, 2013 | Elna Sewing Machines
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
I would like to know how to set the machine up for polyester/spandex material
You need a ball point size 70 or a jersey 70 if you can get it. Stitch length 2.3 to 2.5. Re tension, just normal tension setting. If the machine is sewing an evenly balanced zigzag on regular cotton fabric, then tension is fine. If you find the straight stitch on your fabric pops under stretch, then try using a very small zigzag to put some flexability into the seam.
Mar 28, 2013 | Bernina Activa 140
How do I thread my Delta OL-1000 overlocker
on the website---diplodocs.com---there is a operation manual--pdf file to download FREE
on the first page go to the alphebet letters & find the D & click on it,, it will take you to the next page & in the orange box find the word delta & it will take you to the next page,,go down to the lower part of the page to a box that says TOP USER GUIDES & CLICK ON--ol 1000 & it will take you to the download icon on the left hand side in box that says USER MANUAL DELTA OL-1000..
please rate this
Aug 08, 2010 | Sewing Machines
5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Jan 28, 2009 | Singer 5050 Mechanical Sewing Machine
Proper Settings
A good standard tension setting is usually around 4.5.
If you find it to be looping on the bottom, raise your top tension. If it's pulling bobbing thread to the top, lower your top tension.
For straight stitch, your stitch width should be set to zero, although on some machines (and I believe your Baby Lock to be one of them,) the stitch width setting will change your needle position.
Stitch length is simply a matter of preference.
-R
Aug 14, 2008 | Baby Lock Ellure
Sewing Machines Logo
106 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
