Ihave 14 inch jcv tv first i thought it was dead bt then when i check i saw the fuse has blown i get new fuse to replace it and when i try to switch the tv it blows the fuse again & again .
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Apr 07, 2015
  • 681 Answers
Hi Aderajew, The new fuse also blew away means there is some shot circuit in the TV. No more fuse replacements please. There is nothing more you can do yourself.Take the set to some technician or a service center. Good luck.
  • 44 Answers
SOURCE: philips model 29pt3425-79 flat screen wont switch on
May try to replace your power supply. Average cost runs $200 via Internet. Also may inspect test & replace deformed an or any bulging caps.
Posted on Jun 02, 2009
  • 2318 Answers
SOURCE: proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Posted on Jun 20, 2009
budmrtn
  • 11361 Answers
SOURCE: tv blowing fuses
More likely to be either shorted out bridge rectifier or MOSFET in the primary circuits of the power supply. You need to Ohm out those parts.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sylvania+LC320SS8+
Posted on Dec 22, 2009
  • 8457 Answers
SOURCE: Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
Posted on May 28, 2010
Slinteriors
  • 8617 Answers
SOURCE: Ihave a tv vizio mod vw26lhdtv20f with a problem in the power supply
replace the power supply you can get replacements from www.tvrepairworld.com
Posted on Mar 17, 2012
Wouldn't restart after 10 minutes use
Its an electric saw, I'm figuring if it doesn't work after 10 minutes use its either blown a fuse or the motor.
Apr 24, 2016 | Makita UC3530A 14 Inch Electric Chain Saw...
I have no power
Since you mentioned that the saw is new, why not try calling the manufacturer. It's the best way to you could do for now.
May 23, 2013 | Hitachi C10FCE2 10" Compound Miter Saw
Ihave a 32 inch flat screen Westinghouse tv that comes on with picture for 8 seconds then goes blank. I still have sound....can you help?
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 21, 2010 | Westinghouse LTV-37w2 HDTV
Mastercraft 14-in. Chop Saw w/ Laser fuse problem
The fuse is more than likely, fine.
Instead, check the carbon brushes.
Once you have dis-assembled the unit, you will see the way the springs hold them in.
If you can't find the brushes, chances are, they've desintagrated into micron thick diamonds.
(Unfortunately, they're worthless diamonds lol)
Hope that helps the problem.
Jun 28, 2009 | Saws
No power to tv when i plug it in. don't know if all the way dead way to check it?
I really need the make and model number to help you.
My understanding of what you have said is that there is no standby light and no clicking sounds when you power on your unit. If this is true regardless of what type of tv it is there is a fair chance that the main ac line fuse is blown.
To determine if the line fuse is blown, remove the rear cover panel and follow the ac power cord to where it connects to the circuit board. The ac fuse is a small glass cylinder, about a half inch long. Replace the fuse with the same amperage and ignore the voltage rating. If the new fuse blows as well, your looking at involved circuit work which should be referred to an experienced repair technician.
Apr 29, 2009 | Televison & Video
Goodmans 27 inch LCD
Sounds like the power surge may have blown the fuse in the TV. You can replace the fuse and see if that works. If not, more damage to the power supply unit may have occurred.
Jun 09, 2007 | Goodmans W280NS Television
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
