Question about Garden
Ted & richie46 have been helping me, on the thurmal issue i have, i took off the cover hoping to find a mouse nest, nope. cleaned the fins they were not bad, some rust on fly wheelstrong spark
In our emails i have covered all that i have fixed this is over heating in 3/5min's
SOURCE: HP 7410 Carriage jam error - can I remove the covers
>try to turn printer off and unplug the power cord
>try to open carriage access door
>try to move the carriage left to right if it freely moves then try
positioning the carriage to the center portion
>once thats done. try to plug the power back and turn on
Posted on Jul 03, 2008
SOURCE: replacement covers for black and grey phil and teds
Hello there, I can get these for you (if you haven't got them already). The full set is £108.00, and the bumper bar cover is £7. P&P is £4.95
If you're interested please email me on elizabeth.higgs@mooshmedia.com
Thanks very much.
Posted on May 27, 2009
SOURCE: how do i take the main seat cover off my phil and ted sport
you have to undo the 2screws each side to remove handle, and there are 2 screws on each side near footrest to undo. then it should slide upp the frame and off where the handle bar connects. sounds more complicated than it is should take about 10-15min. then the whole seat can go in the wash.
Posted on Jun 13, 2009
  • 20 Answers
SOURCE: How do i remove the cover of a honeywell home
look under the keypad on each side you will see a small slot , put a small screwdriver in there and push up and it will un hook from the bottom...if this is the most common keypad..send a picture if you can,I have been doing alarms 30 years and have seen it all...
Posted on Sep 13, 2009
SOURCE: when I took the base cover off the vacuum to clean
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays parallel and directly on top of the metal spring, round edge up, and aligned with the open ends of the metal springs.
Posted on Sep 22, 2009
Generator runs but dies out after running fo 3 to 5 mins
Remove the recoil shroud and make sure that there is no mouse nest around the coil area which would cause the coil to heat up and make sure the cooling fins are clean on the engine and flywheel.
Nov 12, 2013 | Briggs & Stratton 20-Amp Extenda Panel -...
Hot engine won't restart.
remove the upper cover from the engine and clean out the cooling fins mice like to build nests under there and that stops air flow
Jun 06, 2012 | Garden
LAWN MOWER STOPS WHEN HOT WILL NOT START UNTIL COOL
heat related problem are more likely to be a bad coil look under the upper engine cover and see if there is a mouse nest stopping air flow threw the cooling fins
Jun 03, 2012 | Garden
Craftsman dy4500 engine overheats
the first thing to check if any air cooled engine is overheating is to take the top cover off the engine mice like to build nests under the cover this blocks off air flow to the engine the fins on the flywheel draw the air and send it threw the fins around the cylinder and heads if so clean it all out and after using it and it cools down place drier sheets around the engine and wiring also spreed them out around a storage shed or garage thet don't like them
May 21, 2012 | Craftsman Garden
I have a John Deere Hydro 175. It will run for 10mins then starts surging and dies. It appears to be overheating. What would cause this?
during the winter a mouse nest might have formed under the tin cover that would stop air flow to the cooling fins
Apr 29, 2012 | John Deere Garden
How do you open a mouse to change batterys
Please follow steps to change mouse battery
First There was a "aa" battery located under the rear top cover. it's the part that has the Logitech logo on it. You simply press the button underneath the mouse at the back that has a LOCK symbol on it & lift off the cover. Put in a new battery & you should be use your mouse
Hope it can resolved your issue
Happy to help
Thanks for using Fixya
Apr 09, 2010 | Logitech MX1000 Laser Cordless...
Phil & Ted Replacement Covers
If you contact Out n About based in the UK, they should be able to put you in touch with a stockist near to you.
I hope this helps.
Aug 21, 2009 | Baby Gear
Mouse nest in defroster and vents
U may be able to remove the blower motor and reach it, this is where they usually nest.
Dec 13, 2008 | 1990 Cadillac Fleetwood
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
