I have just noticed fore the first time, that during the drying process starting around the 2 mins I can hear a whurring noise which lasts around 30 seconds every 10-15 mins, any one know what it is?
SOURCE: LG WM1812CW noise
Other than seperating the drums you could try to remove the heater element which will allow you limited access to the cavity between the drums. Shine a torch in there and rotate the inner drum slowly untill the offending piece comes into view. Remove with a long tweesers or hook.
SOURCE: Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
SOURCE: Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
SOURCE: Why is my LG washer/ front loader Model (WM2233HS)
two things could be wrong the fist check that the filter is not blocked its at the frunt bottom right near the floor right side put towls down theres still 10 cups of water in there ok pif you can twist the black or it could be white knob take it right out then check to see if its empty if it is then it sounds like you moter brushers ok i can onlt try to help ok please rate me if i have helped you
SOURCE: the load starts out with
not sure but sounds like a mother board is playing up, try turning it off at the wall over night just to see if it will reset itself.
if not you will need to keep asking.
