Question about Video Game Consoles & Games
WILL MY RACING WHEEL WORK FOR ASPHALT 8 AIRBORNE
What is altimeter means
The altimeter records your elevation above sea level. Useful when mountain climbing, Tour De France cycle racing the mountain section or flying, which I am sure you do almost every day :>)
Mar 04, 2016 | Watches
How do I calibrate my concept 4 steering wheel for my play staion 2
Keith, The wheel you have has an intentional dead spot (0) in the center position. There are several ways to assign buttons, and even select a different center, but in the center position, it will always be (0) The PS2 version of this racing wheel lacks the proper calibration settings to make the (0) zone smaller like other analogue controllers. I have the same issues with the same racing wheel for the Xbox, and other after market controllers. The manufacturer does not consider analogue "sensitivity" when making a controller. That keeps costs down, and lets them produce an "Average" product, instead of a "SYSTEM STANDARD QUALITY" product. A prime example of this, is the Wheel in question. (0) is hands off of the wheel centered. +1(right) 1/8 rotation before connection for controls. Think of the wheel as a piece of pie. you only get 1/2 rotation in either direction. The concept 4 slices it into 1/8 for analogue control. A quality wheel (expensive) slices the pie into 1/16. I hope this helps. When it comes to racing wheels, it's user preference.
Oct 21, 2015 | Sony PlayStation 2 (PS2) Console
How to replace rear wheel bearing on 1994 bmw 325i
3-Series (Except M3, M Roadster, M Coupe, 318ti & Z3)
1. Raise and support vehicle. Remove wheel(s).
2. Remove axle shaft. See appropriate AXLE SHAFTS article.
3. Remove brake disc. See BRAKE DISC .
4. Screw special tool (33 2 116) onto drive flange with wheel studs. Drive out drive flange with special tool (33 4 201/202/203). See Fig. 33.
5. If necessary, pull off bearing inner race using special tool (00 7 500) and a thrust piece. See Fig. 34.
6. It may be necessary to remove inner wheel bearing race with the following procedure:
  • Detach wheel bearing inner race with special tool (33 4 400) through groove in bearing inner race.
  • According to outside diameter of bearing inner race, use special tool 33 4 401 with: 33 4 405 for dia. 45-51 mm, 33 4 406 for dia. 50-55 mm and 33 4 407 for dia. 55-61 mm in groove. See Fig. 35.
  • Tension special tool 33 4 401 with wrenches 33 4 403 and 33 4 404 until it can still just be turned in groove. See Fig. 36 .
  • Screw in special tool 33 4 402. Detach inner bearing race.
7. Remove circlip. See Fig. 37 .
8. Remove wheel bearing with special tool 33 4 031/ 041/ 042/ 043/ 045. See Fig. 38 .
CAUTION: Do not reuse old wheel bearing.
9. Draw in new wheel bearing with special tool 33 4 041/ 042/ 043/ 047. For inner bearing race 42 mm use special tool 33 4 049 and for 39 mm use 33 4 046. See Fig. 39 .
10. Installation is reverse of removal.
11. Replace stretched or damaged circlip. Ensure correct seating.
12. Pull in drive flange using special tool 33 4 041/ 042/ 043/ 045/ 048. See Fig. 40 .
13. Install brake disc.
14. Install axle shaft.
Nov 12, 2010 | BMW 325 Cars & Trucks
Hi When I ride with my KTM530EXC-r on asphalt
try dropping the fork tubes up through the yokes about 10mm or 20mm
Feb 15, 2010 | 2008 KTM 530 EXC-R
Code to unlock asphalt 4 elite racing on samsung corby gt - s3653 mobile
what is the code for unlocking asphalt 4 full version for samsung corby gt s3653
Dec 13, 2009 | Cell Phones
Use of a Sait Cut abraise wheel to cut PVC Pipe
I worked at a tool rental business while going to college and became familiar with OSHA requirements as it pertains to construction. There is an old saying that if you follow the rule-book by the letter things will quickly come to a grinding halt. I checked on OSHA web site and could not find anything on you question. I recall that using the correct blade only results in a cleaner cut, however there is the possibility that the pvc material can load-up on the blade and cause jambing. An inspection of the blade will answer this. More important is that all safety items are in place like the blade guard and that all workers in the vicinity of the saw are wearing eye protection. We used Norton brand abrasive blades and the following is their guide. APPLICATION GUIDE:
Concrete:
For concrete/masonry - silicon carbide specification for brick, block, concrete, and other masonry materials.
Metal: For metal/steel - aluminum oxide specification for mild steel, stainless, and metal decking.
Asphalt: For use when cutting mostly asphalt.
Asphalt / Green Concrete: For asphalt and green concrete - silicon carbide in coarse grit range. For high performance, hot pressed wheels provide significantly longer life.
Ductile: For ductile iron and cast iron pipe - formulated with a special blend of silicon carbide (for cutting) and aluminum oxide (for long life). This specification is also suitable for cutting PVC.
Hope this helps, enjoy
Dec 09, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Video Game Consoles & Games Logo
1,428 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
