Question about Pool & Spa
Our heater will fire up and come to temperature but will not stay at temperature. We have to go out and turn it back on. Any suggestions?
  • 1,631 Answers
What heater?
make & model?
What do you mean exactly... when you say... go out and turn it back on?
What will the difference in temperature be from actual water temp, to set temp on heater?
Posted on Apr 07, 2015
Testimonial: "We have a Pentair MasterTemp 250 MSTRTMP 250 is the Model MN25 03/07/08 180 is the Serial number So the heater turns on and runs if you turn it on. It reaches temperature and the naturally shuts off. When the temperature lowers due to cooler weather the heater doesn't recognize and turn itself back on to maintain the desired temperature. We have to go and manually turn it on again ourselves."
I have a weatherking model 80PJ07EBR01 . When the heater comes on the gas fires up for just a couple of seconds and then turns back off. Any suggestions? Could it be the thermocouple?
If the pilot light is staying lite (if it has a pilot light) and if the burner is lighting and then going out, it could be the thermocouple. that is a relative cheap part and very easy to install. Make sure you have the gas turned on and the lines are not bent. BE SURE TO TURN THE GAS OFF AND THE POWER SOURCE OFF BEFORE ATTEMPTING ANY REPAIR.
Dec 10, 2016 | Heating & Cooling
How do you increase the water temp?
Hi Donna:
The temperature is pre-set and is intended to be not too hot to inadvertently burn someone. Increasing the setting can cause a real SAFETY HAZARD, especially if small children or seniors are involved.
With that in mind, there will be a panel that unscrews from the side of the heater. After removing it, lift the insulation back and a dial should be visible. There will be numbers, and a pointer with a screw slot in the centre. Turning the pointer to a higher number will increase the temperature.
If you are going to adjust it, only do so a very small amount at one time, until you reach the desired temperature.
Remember, increasing the temperature will not give you more hot water, it will only give you hotter water. If you need more hot water, consider getting a larger tank or an "on demand" gas fired unit.
STAY SAFE!
Jan 12, 2016 | Water Water Heaters
My pilot stays on on my propane furnace but will not light up
The Little Giant units use a Unitrol gas valve very similar to a water heater in the home. #1,urn the Unitrol gas valve to the "PILOT" position to ignite the pilot. Depress the plunger and hold it down then push the spark igniter button until you can see the pilot flame ignite.
You have a lit pilot so this is not a problem for you.
The pilot light stays on continuously by design.
Once the pilot flame is established, you then turn the on/off/pilot valve to the "ON" position and set the thermostat to the desired temperature range., it should then fire its main burner until the desired temperature is reached. Once the temperature is reached, the main burner will shut off and the heater will go into a standby mode with the pilot flame still burning.
If you have turned the pilot valve to on and set the temperature high, it should come on, if not a new gas valve is required, they can be very difficult to replace due to rust.and most cases require a new unit,
Mar 19, 2015 | Unitrol Propane Heater Valve - Little...
Why wont hot tub heat with jets on losing temperature on 110 volt
My first question would be about the outside temperature. What is the outside temperature?
Hot tubs that are designed to operate on 115v only have 1.5kw heaters and if the outside temperature is below 50 deg F they tend to not keep up to 103 deg water while being used. They are also designed to not heat while the high speed pump is operating.
Does it stay up to temperature on a normal basis?
ROD
US Parts Center
Jun 08, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Raypak pool/ spa heater Low NOx Model 407A: Will take long time to fire, stays in spark mode, and then when iit does fire, it shuts off and takes long time to fire again. If you can get it going it stays...
The pilot is not proving to the control.Check that there is a GROUND/EARTH stake to the pool heater in the dirt.The pilot assembly needs a ground wire too the control.
Sep 16, 2010 | Heating & Cooling
Fluctuating temperatures
Sounds like there is not enough flow in order to keep the burner in the heater firing continuously
Jul 09, 2009 | Rinnai Webstone The isolator EXP tankless...
My heater starts and then after about 3 seconds shuts off
Either , you really don't have good pressure (below 18 PSI on filter) or your water pressure swith is defect.
Try placing your filter on "recir" and fire the heater , if it fires and stays on .....it's definitely your pressure -back wash.
hope it helps
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
My Jacuzzi won't turn off or heat
The heater will only fire if it has water in it. If you just got the house, make sure the gas/electric to the heater is on. Turn off the pump and turn it back on.. See if that works. good luck
Jun 05, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Bradford white 15 yr old power vent runs constant
pilot light will stay on if it is a standing pilot. Turn water heater aqustat down and plug back in. you probably need to clean water heater or replace it. i have drained down a couple of them and took out gas valve and cleaned and put back in worked fine. If you get me a model # i can look it up and tell you some things to try. not sure on yours if it has a different temperature control or if the gas valve is a dual control .
Jan 30, 2009 | Water Heaters
Pool & Spa Logo
115 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
