Question about Health & Beauty
I need the wiring diagram to re-connect the power, switch, and motor.
    Top Expert:
  • 10,875 Answers
Tip
How to Hot-Wire Test a Cordless Drill Motor
<span><span>The power switch may not be the problem if a cordless drill stops turning on. Sometimes a bad drill motor can prevent the tool from starting, even if the switch is good. </span></span><br /><span><span>To determine the problem, the best method is to remove the switch and then hot-wire the drill motor to the drill's rechargeable battery to test it. If the motor checks out, then it's probably the switch. </span></span><br /><span><span>The steps for testing a drill motor .</span></span><br /><span><span>In addition to tools needed for dismantling the cordless drill, such as a drill/driver, <b>two</b><b> wires</b> are needed to connect the motor wires to the drill battery. </span></span><br /><br /><span><span><span style="text-decoration: underline;"><b><a></a></b></span>Hot-Wire Test a Drill Motor</b></span></span><br /><span><span><span style="text-decoration: underline;"><b><br /></b></span></span></span><br /><p><span><span>1. Remove the drill's battery and dismantle the drill.</span></span><br /><p><span><span>2. Disconnect the wires leading from the switch to the drill motor. Sometimes this means completely removing the switch. </span></span><br /><p><br /><p><span>3. Now that the motor is isolated from the switch, <b>connect </b>one of the <b>motor </b>wires <b>to </b>one of the <b>battery </b>contacts <b>using one of the two wires</b> set aside for this test.</span><br /><p><br /><p><span><span>4. <b>Connect </b>the <b>second wire </b>to the other battery contact. </span></span><br /><p><span><span>(<b><i>Note:</i></b> It does not matter which motor wire is connected to which battery contact. The orientation is not important because it is a DC motor and will only determine which direction the motor spins.)</span></span><br /><p><span><span>5. Hold the motor firmly in one hand, and then <b>complete </b>the electrical <b>circuit </b>between the battery and the motor by connecting the second wire to the the second motor wire.</span></span><br /><p><span><span><b>If</b> the <b>motor does <i>not</i> spin</b> once the second connection is made, <b>then the drill motor</b> <b>is most likely fried</b> and needs to be replaced. </span></span><br /><p><span><span>If the motor <b><i>does </i>spin </b>after completing the electrical circuit, that's a good indication that <b>the motor is</b> a <b>healthy </b>one. If the motor tests out OK but the drill is still having trouble starting up, the problem is most <b>likely </b>caused by <b>a faulty power switch</b>, not the motor.</span></span><br /><p><br /><span><br /> </span><br /><span><span>The power switch will have to be reconnected to the drill after the motor has been tested. It is important to reinstall the switch wires correctly after performing this test. </span></span><br /><span><span>The example drill used in this article has a very simple wiring configuration in its power switch. Drawing a switch wiring diagram is especially useful for switches with complicated wiring configurations.</span></span><br /><br /><span><span>If you're testing your drill's motor, chances are that some kind of part replacement is on the horizon. </span></span><span><span></span></span>
on Nov 13, 2010 | Drills
How to check fan blower switch I need diagram of the switch
id find blower motor and hit it with a hammer if it turn on its bad also look at the wire to the resistor they melt down if its bad put new connector and resistor in iv done a few
Mar 04, 2015 | 2005 Chevrolet Silverado
I am putting doors on my 1984 ford f150 from a 1985 ford firo which has power windows I need a diagram to wire power to the switches
You don't need a diagram, just power thru the doors at the hinge. Run 2(two) wires, one black and one red, thru an opening at the door hinge, even if you have to make the opening. Go to any fuse in the panel and find which is the hot side by pulling the fuse and test for the hot side. Stick a fuse tap on that side of the fuse and put the fuse back in. Get this fuse tap from any auto parts store. Get a pack of female spade connectors to connect the red wire of the wire size needed. Size 10 will do for this. Get some size 10 straight connectors also. Connect the red wire to the hot wire going to the window motor. Connect the black wire to the ground wire on the motor. now connect the other end of the black wire under the head of a bolt under dash. First in mind though, be sure the fuse you connect the red wire to is switch activated when on and off when switch is off. Power windows are great when you gottem. I plan on doing my Toyota with window power units from an Oldsmobile. It will happen. Breeze on Bro.
May 26, 2017 | Cars & Trucks
Will not turn over! Starter won't engage!!
When you turn the key to on, do the dash and warning lights come on? This would verify power to the ignition switch.
It's like this: you have a positive battery cable with a lot of juice connected to the starter, but not to the starter motor. It is only connected to the starter motor when the start wire out of the ignition switch energizes the starter solenoid, mounted on top of the starter.
So you check the small wire to the starter for power with the key held in start. If it has power then, the starter or the solenoid is probably bad- as long as the battery is charged and the battery connections and starter connection is good.
If you have no power on the small wire in start, trace the start wire back to the ignition switch. You may need a wiring diagram- there is often a start relay, a park/neutral safety switch with automatics or a clutch safety switch with a manual transm., and sometimes a "crank" fuse. All or some may be in the path of the start wire from ignition switch to the starter solenoid. You would need a voltmeter or test light to check this circuit. If you want more help, post back with make, model, year, and engine, and I could look at a wiring diagram for your start circuit, or I could post a link for you to see the diagram.
May 03, 2014 | Cars & Trucks
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Essick air compressor wiring diagram
telepathy do not work that hot as in hollywood movies...
you need to provide a model or at least if this is three phase or single phase...
single phase is easy, you have cord with three wires, earth, active and neutral.
you need to open connection box on your compressor and you will find three wires there terminating in junction box, earth connect to earth (usually green or green with yellow stripes), then you have your neutral (usually brown or black) and active (usually blue or red), connect them, do not put cover on yet, plug cable into the power point and switch on/off power. check if motor is rotating in correct direction, if fuses are not blown... if motor is rotating in wrong direction - switch power wire with neutral wire, it just meant that you wired it in reverse...
do not need diagram for that...
do not forget to give some points...
Dec 30, 2013 | Park Tool Inf1 - Shop Inflator For Use...
I nead a wirring diagram to fit a four connection power switch to a Kirby G4 cleaner
There isn't a wiring diagram for these. There is only a switch, a motor and a light, so a schematic isn't really required.
I'm assuming you've made the fatal mistake of removing the wiring from the old switch and have forgotten where to re-connect them. It's also not very helpful that all the wires are white, so I can't really tell you to connect red to "x", black to "y", etc.
The really important connections are the power cord and the motor brush connections. You can't get the power cord wrong as the plug is shaped to only allow connection at one orientation: I've drawn you a diagram to show 3 of the 4 connections:
As long as the motor brushes are correct, there wont be any problem. If these are the wrong way around, the motor will run in reverse and will blow instead of s/uck.
The headlight can be wired either way around so if these connections are switched, it shouldn't matter. You have a 50/50 chance of getting it back the same way as it was originally and if there is any problem with the light, you can easily switch these wires over.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Kirby G4 Bagged Upright Vacuum
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Feb 13, 2009 | Hitachi 10", Table Saw with Stand,...
Health & Beauty Logo
90 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
