Question about Plumbing
No water pressure for hot or cold for new faucet just installed
Is there something to increase water pressure
Have just installed a Pfister F-8H6-85 and have similar issues with low water pressure. The unit I replaced had fine pressure. Spoke with Price Pfister and their sending me a replacement diverter valve as well as new hot and cold stem valves. We'll see.
Posted on Apr 07, 2015
    Top Expert:
  • 10,875 Answers
Turn on the shut offs under sink
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
No hot water pressure
These types faucets have a what is called an anti scald valve build into them, it is required by law, it is either defective or out of adjustment, contact a local hardware store for more detailed info.
Feb 02, 2012 | American Standard Plumbing
R120 Valve I have good pressure with the cold water but no pressure with hot water
I imagine you have the installation instructions since you just installed it. Your new shower handle has a hot limit safety stop. You can set this with a flat blade screwdriver. The safety stop is the red ring in the handle and all you need to do is pry the ring forward with the screw driver and rotate it clockwise to increase your hot water.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 12, 2011 | American Standard R120 Pressure-Balance...
Hi just moved in new home love it but the water pressure in kitchen is very low but the two baths i have the water pressure is fine can you help me please
One thing you could try is to remove the aerator at the end of the spout on the faucet, Turn water on and see if pressure is any better. If so the aerator is got something in it restricting the flow.
You also can remove the dime shaped flat in the aerator to increase water flow. It looks like a dime with a hole about 1/8" in center to restrict the flow to about 1.6 gpm. Remove it and reinstall aerator and check water flow
Most of the times when cold and hot side of faucet.It would be the first thin to check being you have good water pressure at other faucets. They catch debris and the flow slows down from the faucet's. Check out supply lines and faucet for a blockage if this doesn't take care of the problem.
Check out this web sire for a parts breakdown of parts in faucet. Check out installation and rough in sheet for information on faucet below.
http://www.needplumbingsupplies.com/Kohler-Kitchen-Sink-Faucets.asp?id=3628
Jun 15, 2010 | Kohler K-12176-PB Fairfax Single Handle...
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Dec 15, 2009 | Water Heaters
Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Aug 31, 2009 | Plumbing
''poor pressure hot water only on new 531 series''
If you remove the supply line from the faucet and open the valve into a bucket, do you have adequate pressure? If you do, you will need to remove the hot water stem to see if something washed up into the faucet when you first turned the water on.
Apr 10, 2009 | Price Pfister Savannah Two-Handle Kitchen...
Grohe bath faucet adjustments
Do you still have the owner's manual of the faucet? if so check under troubleshooting. It sounds like, most grohe products, a pressure problem. Did you check the pressure coming into the house? Do you have a water regulator outside the house? If so check the pressure.
Feb 21, 2009 | Grohe Plumbing
Plumbing Logo
186 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
