Question about SingerAAAA Patchwork TM 7285Q Sewing & Quilting Machine
Why can't I thread with automatic thread feeder
I got the thread through the machine,but can't get it to thread
  • Singer Master
  • 1,860 Answers
The automatic thread feeder may need some type of adjustment, so if the problem persists, you might need to have the machine checked
Posted on Jun 03, 2015
I have a a Janome 6260. The thread eVentually splits in half, then breaks. This problem is worse when I use decorative stitching
I'm going to guess on this one; if your stitches are even (no bunching or pulling), you might have a build up of thread somewhere in the machine. Take out the bobbin and, if possible, the bobbin casing and check for any tangled or loose threads. Second guess, check the feeder on top of the machine, thread may be working its way into and catching on that feeder... be very careful when threading through the feeder because thread will often catch. If neither of these 'fixes' work, might be time to take the machine in for a cleaning and tuneup.
Dec 05, 2014 | Janome Sewing Machines
Feeder not moving
knotted up thread under the material indicates that the needle thread tension is incorrect ( needs tightening)
once you have that correct the material, will feed normally
use scrap when adjusting and the correct tension is when the top and bottom threads meet at the join ( middle -center )of the materials being sewn
Aug 09, 2014 | Elna 2007 Mechanical Sewing Machine
Thread not picking up
Have you checked that your machine is threaded correctly?
Have you checked that the thread is correclty placed in the bobbin feeder and pulled through correclty?
Mar 01, 2014 | Singer CE-200 Quantum Futura Computerized...
Uneven feed
machines can have single or double feeders. what type does yours have? feeding problems can usually be fixed by a good cleaning+ oiling of the feeder mechanism which regularly gets clogged with lint+threads/scrap threads. brush it out thoroughly with a stiff-bristled brush like an acid brush. apply 1 drop of oil to each feeder seen on the foot-plate. wipe excess oil off with a clean dry rag being sure not to get any debris from the rag caught in the feeder(s). other problem might be your bobbin tension. this is usually adjusted on the bobbin race with a very small screwdriver.
Feb 22, 2014 | Brother PC-420
Find free manual for white japanese sewing machine model #1010
check this link & see if it's the manual you need
http://www.singerco.com/uploads/download/738_white-445,988,999,1010-x.pdf
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
the feeder bar, do you mean the feeddogs, that are in the needle
plate?
for the feeddog part try sew4less.com
Aug 14, 2012 | White Sewing Sewing Machines
Feeder dog is in reverse and thread won't feed through bobbin..
it would really be a good idea to have the machine serviced at a sewing
machine shop
May 05, 2012 | Sewing Machines
Pfaff 2170 - during embroidery, the nylon thread gets all shredded up in the machine before getting to the needle and needle thread feeder and breaks. No problem when using the heavier weight threads like...
Nylon thread is difficult to use as a top thread. When taking a special class, we set the spool on the table behind the machine with a thread net over it. A safety pin or paper clip was taped to the top of the machine like a thread guide before running the thread through the tension mechanism. For the most part, a lot of instructors will advise using nylon thread in the bobbin but not as a top thread,.
Dec 23, 2017 | PfaFF Sewing Machines
Feeder not moving thread is bunching up How do
I took off the foot, plate and where the bobbin is kept. Cleaned it out and there was a thread that was caught there. I put it back together and it worked fine.
Thank you
Patti
Oct 29, 2009 | Husqvarna Freesia 415
Brother 925D - threads do not lock
threads do not overlock stich
Aug 11, 2008 | Brother 925D Serger
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
SingerAAAA Patchwork TM 7285Q Sewing & Quilting Machine Logo
66 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
