Question about Garden
There,s no power coming in from the mains ,what is the problem plx.How can i detect the problem plz?
Sony dsc-hx100v how the chang language into english
If you press the MENU button while shooting or during playback,
(Settings) is provided as a final selection [icon is a case].
You can change the default settings on the (Main Settings) screen.
The Main settings icon is a [wrench + hammer].
The Language Setting is the third option.
Oct 14, 2014 | Sony Cyber-Shot DSC-HX100V 16.2 MP Exmor R...
Help me Plx! whenever i activate hot spot shield, IE page start opening every 5 minutes called(anchorfree.com). how can i get rid off this? plz Help
Try to down load free software (Why should I remove it)..And use this application to remove stubborn adds.
Jan 04, 2014 | Computers & Internet
I have power mp3 in my nokia 5233 hw i get registration key? if u have plz tell me
I HAVE INSTALLED POWERMP3 1.17(0). I WANT THE REGISTRATION KEY
Jun 27, 2012 | Nokia Cell Phones
How to connect the planronics plx500 to the phone? what is the use of each one of the bottoms?
Unfortunately finding life on another planet would be easier than locating an ancient (electronic years) PLX-500 user guide. However, I happen to have one of those ancient writings (no, it wasn't in a cave at the Dead Sea), albeit a bit tattered and yellow, so I'll try and give you a rundown of it's various features.
The top buttons for headset/handset and mute, and listening volume wheel are pretty self-explanatory. Now let's talk about connecting the PLX-500 to your phone and the other amplifier features.
1) Disconnect the telephone handset cord from telephone base and insert the PLX-500 modular plug into the handset jack on the phone. You then insert the coiled handset cord into the back of the PLX-500 base (there's only one place it can go into).
2) Plug the cord from the headset into the jack in the front of the PLX-500.
3) On the back of the PLX-500 base there are two switches (1-2 and 3-4). These are used to configure your PLX-500 to your phone (most electronic single and multi-line phones, such as Panasonic, will use setting 1 and 4). You will have to configure the PLX-500 to your specific phone. Having connected your PLX-500 to your phone, put on your headset, press the headset button on the base, lift the handset of the phone cradle and listen for a dial tone. Adjust the switch settings until you hear the best dial tone.
4) Remember that your PLX-500 uses batteries located under a cover on the bottom of the base (some phones will work without your PLX-500 needing batteries, check configuration before installing batteries). Speaking of the cover, there is a small plastic screwdriver attached to it that you use for adjusting the volume of your microphone. That adjustment is located on the back of the PLX-500 base next to the configuration switches.
Hopefully this gets your PLX-500 up and running.
Good luck from Headsets Direct!
Aug 31, 2011 | Plantronics PLX500 Headset
Forget my c101 security lock password my phone is locked plz help...
helw guys i am in a great problem with my nokia c101 i forgot the security code unfortunately and now i want u guys 2 help me out plzzz...i tried all default codes but its says like code error plx guys help me..
Mar 14, 2011 | Cell Phones
I lost my nokia x2 security code how can i reset
FOLLOW this link http://forum.gsmhosting.com/vbb/f550/how-remove-security-code-nokia-x2-step-step-guide-1139563/
Sep 17, 2010 | Nokia Lands Phones
Logic soundlab plx 46 red led lit in center of board what does it mean?
does it have sound if not it may be on a protect or themal mode try taking our=t your main fuse when the system is in and put it back in
Dec 17, 2009 | Logic Soundlab PLX-520 Car Audio Amplifier
Missing manual
go here:
http://www.qscaudio.com/products/amps/plx/plx.htm
right hand side of the screen....
documents...
plx users manual...
download...
enjoy !
Remember to rate the answer !!!...
thanks
Rob
Jul 28, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Car audio
Product Details and Features PLX-520
Key Features
Amplifier Type grayquestion.gif Dual Channel Bridgable grayquestion.gif Bridgable RMS Power at 2 Ohms 400 W x 2
Performance
Frequency Response 10 Hz - 50000 Hz Signal to Noise Ratio grayquestion.gif 102 dB THD at Rated RMS Power 0.01 %
Crossover / Equalizer
Bass Boost grayquestion.gif With Bass Boost Low - Pass Frequency 50 Hz - 120 Hz High - Pass Frequency 80 Hz - 800 Hz
Other Features
MOSFET Circuitry Yes 3 Way Ready Yes
Dimensions
Width 10.4 in. Depth 17.7 in. Height 2 in. ..This is what I found for logic soundlab PLX-520 Amplifier, hope its what you were looking for. Don't forget to rate answers.
Mar 31, 2008 | Logic Soundlab PLX-520 Car Audio Amplifier
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
