Question about Goodman Heating & Cooling
Goodman minisplit flashes on pre. Def. Wont start
  • 998 Answers
If what MM suggested doesn't work, I would say that the refrigeration system isn't working. Pre def means that the indoor unit is waiting to get hot before it starts again. Feel the coil behind the filter, it should be getting hot when on heating mode. If its getting hot and the machine is still sitting on pre / def, it is most likely that the indoor pipe sensor has failed. This sensor triggers the indoor unit to start once it has reached operating temperature. If the coil is not hot, check that the outdoor unit is actually running. When on heat mode, the outside unit should be blowing cold air as the hot refrigerant is now going inside. If the outside unit is blowing warm air , then that would indicate that the reversing valve system is not operating.
Posted on Apr 13, 2015
    Master:
    Sergeant:
  • 394 Answers
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Repair Tamarac
Posted on Apr 12, 2015
Toshiba AC Pre-Def orange light is flashing as well as operation green light is flashing. What could the possible fault be.
Please re post and include the model number and place the question under the correct heading for our experts to pick up for you. This is laptops.
Dec 24, 2016 | Toshiba Computers & Internet
Teco LS1209Y faults pre-def
How do you take the cover of to get to the filters
Oct 16, 2012 | Heating & Cooling
Hi, My Mother has a stand up goodman in her attic that we are having problems with. The gas valve went out so I replaced it. Then the pre-vent blower went out, so I replaced it. Now it seems that the...
Verify that it has 120 volts present at the inducer motor connections. If it does then replace the motor again. If it does not then you will need to replace the circuit board.
Dec 11, 2010 | Goodman GMS90703BXA Heater
All lights are flashing including Pre Def, Timer, Operation and Auto but air conditioner is not functioning
Not sure the make and model of your equipment you have there but sounds to me like your control board is trying to tell you it is bad.
Jun 12, 2009 | Heating & Cooling
Goodman GMP050-3
If you do not have two furnaces hooked together, you have a bad circuit board or an improper ground or neutral wire.
Dec 09, 2008 | Goodman GMS90703BXA Heater
Minisplit flashing code - water dropping
Check your air filter and indoor coil fins if clean. If it is dirty it need to be clean. But if it is clean you need a qualified technician for this problem.
Jul 30, 2008 | Heating & Cooling
Our toshiba ras13 skv a heat pump keeps going to pre def mode and not heating the house
this happens when the outside temp is low, asthe outdoor unit blows cold when in heating (reverse) then the unit goes to pre def to avoid it freezing. You should hear a whoosh this is the heat being blasted to the outdoor unit to defrost it, then the heat has to build up again before the indoor unit fan runs up again and blows heat. Mine does the same every 20 mins or so (its -2 outside) brrrr
Leigh
Jun 18, 2008 | Heating & Cooling
Heating & Cooling Logo
717 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
