The washing machine fills then starts to heat up. once at temperature, it drains, missing out the rest of the cycle
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check motor brushes or capacitator
Posted on Apr 12, 2015
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Intermittent fault
you have tried all ways its better to go to the mechanic it can help out more if he can find out some related problem
Thanx
Dec 02, 2007 | Candy AQUA1000T Front Load
Cycle wont move on withhotpoint 220
check the heater once its filled it will stay in wash until it heats to the correct temperature so if the heater has failed it will stick in programme
Feb 27, 2014 | Hotpoint Washing Machines
Not heating up to temp of 150 for wash cycle
The 737, like most Jet=Tech models, requires to be drain empty at least once a day. If the unit is empty and it is started, it will take approximately 30 minutes for the machine to be ready. Which means, the unit will fill and then heat up both booster tank first and then wash tank. If after all that the wash temperature is not up to 150f then the wash thermostat needs to be either calibrated or replaced if the wash element is in good condition. It is assumed here that the booster temperature is reaching 180F.
Search by part number or description Search by part number or description
Nov 20, 2013 | Jet Tech Systems 24 in. 737 Free-standing...
Stops mid cycle and clears
It could be the heating element is at fault not heating to the selected temperature 95 degrees 40, 30,and so on, if one of these fail to work then the washer will not continue
also maybe the thermostat may be at fault, causing the same error
Nov 18, 2013 | Zanussi ZWF1020 Front Load Washer
The wash cycle is taking a lot longer to do, for example the 30 min wash is taking 1 hour and sometimes longer, the motor seems fine, could it have something to do with the pump
Hi.
When the cycle hangs it means that because of a fault the conditions to advance are not met.
If the washer hangs at start (filling), then there is either a problem with water pressure, blocked inlet, or water flowing back from drain hose because of incorrect hose settings (called siphoning).
If machine hangs mid cycle, then it is often a temperature related problem. Check thermostat and element or check hot inlet and thermostat if dual inlet. Testing requires disassembling and use of the multimeter.
If machine hangs mid cycle or end of the cycle (before spin), then it can be drain system. Check drain hose, drain filter attached to pump and check the pressure switch.
Most machines have a service sheet hidden inside the control panel assembly. The tech sheets shows how to run a diagnostic cycle that will tell where the problem is.
Most common faults resulting in long cycle are heat-related and drain problems.
Regards.
Ginko
Jul 17, 2011 | Samsung Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Washing machine doesn't wash
E8 Means the temperature is too high. Replace the thermistor - temperature sensor, also known as NTC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 10, 2009 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
