Question about HP DesignJet 800ps InkJet Printer
Hello. My HP Designjet 800ps says "too little ink to prepare the ink system". I want to know if there is something that i can do to erase this error.
Every time I turn it on the printer asks to remove the printheads to prepare the ink system. I follow the instructions and at some point says: "too little ink to prepare the ink system". I want to know if there is something that i can do to erase this error.
  • HP Master
  • 1,915 Answers
It sounds like the printer has been set to initialize as if new and thinks that there is no ink in the tubes so it wants to do a full prime. Other than replacing the carts and letting it run I am not sure there is another way.
Posted on Apr 16, 2015
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
Posted on Sep 10, 2008
yooperbud
  • 8637 Answers
SOURCE: I have a hp 7580
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
RPFinney
  • 385 Answers
SOURCE: hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Posted on Apr 17, 2009
ingenito
  • 11 Answers
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
SOURCE: HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Posted on Dec 05, 2009
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
Error 05:09 in HP Designjet 800ps, what to do?
I assume if you have the service manual it means you are going into the correct eeprom area to setup the model. It is possible that the HPGL portion of the card has failed, or the hardrive is bad.
Apr 08, 2015 | HP DesignJet 800ps InkJet Printer
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
SYSTEM ERROR 20:10
Error Code 20:10 does not appear to be a valid code. Could you verify that is what is being displayed? What is the plotter doing when the error occurs?
Oct 03, 2013 | HP DesignJet 800ps (24 in.) InkJet Printer
HP Designjet 800ps 24". How
Instructions are usually supplied with the belt, however if you are looking for the manual, you can find it here!
Jul 05, 2011 | HP DesignJet 800ps InkJet Printer
HP DesignJet 800PS resets everytime I send it a job
try removing the jetdirect card and sending something direct via the usb port. if this doesn't work then you may have an issue with the main pca.
Aug 15, 2009 | HP DesignJet 800ps InkJet Printer
HP Designjet 800PS
It's Not a part of Carriage assy , but its a part of Ink Tube Assy
plz Replace that to get it in working condition
btw it's 42 inch or 24 inch
Mar 24, 2009 | HP DesignJet 800ps InkJet Printer
HP DesignJet 800ps InkJet Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
