Question about Dell Computers & Internet
Dell latitude 10 st2 e wont boot
Wont boot but white light power light works have replaced long battery and power suply
    Sergeant:
  • Dell Expert
  • 352 Answers
Hi voyagerbooks,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30 sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs shown on it.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Posted on Apr 10, 2015
harvester3
  • 181 Answers
SOURCE: dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Posted on Nov 27, 2008
SOURCE: Periodic Boot-up Problems with Dell Latitude D600
Well I had the same problem with my Dell Latitude D600. I tried many batteries, fully charged, partially charged and even i tried scenarios with AC Power On or Off. Nothing really seemed to work as my laptop was both hot and cold. I noticed this problem was coming specially when laptop is cold.
The Solution is found is, when i have this problem, i press the power button and then move the rotate the laptop, so that its screen touches the desk and keybord is upright verticle, i know it sounds ODD, but it really made my life so easier as now this problem doesnt haunt me.  and it will boot on first, second or third go.
Normal Laptop Condition with keybord down and LCD Open
                     /                     /      / lcd
__________/
You need to move the laptop in one of the following if it is having boot problem again
       \               /          \            /            \         /  keybrd  \      /  lcd                \   /                 \/
or put the lcd down flat while keeping the keyboard in the same position as above.
I m sorry the above illustrations are pretty rough but hope u understand what i mean :)
Posted on Dec 13, 2008
SOURCE: Dell Latitude D510 fails to power up
the battery can be shorted so that parts or the unit may have problems in
Posted on Jul 20, 2009
benwabnick
  • 2404 Answers
SOURCE: dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Posted on Nov 30, 2009
2coolrick
  • 560 Answers
SOURCE: dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
Posted on May 13, 2010
Testimonial: "Excellent purchased the new adapter and and what do you know problem solved.Thanks a million."
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Dell latitude runs but does not boot up
Remove battery + power cord from AC adapter. Wait 10 minutes. Plug in only the power cord. Power-on the laptop.
If laptop starts correctly, plug in battery while it is up using the adapter. Leave on for battery to recharge.
Oct 19, 2011 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
D600 wont power up
Try removing the battery and boot on the power cord sometimes the battery shorts the system so it will not boot if it does boot then you need to replace the battery it could be the battery is dead and your power cord is bad check and make sure that is not the case if the power cord is good then I would look into replacing the mother board you can find a replacement on Ebay or at dell .if you have to replace it do a google search on hot to replace the mother board on a Dell latitude D600
and you will ba able to get step by step on how to disassemble it
Aug 28, 2011 | Dell Latitude D600 Notebook
My dell inspiron mini 10 won't boot.There is just this annoying sound that wont stop.
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else. I've removed the battery and unplugged the unit and put it back together and it still does the same thing. HELP!
Apr 21, 2010 | Dell Inspiron Mini 10 Notebook
My dell latitude d600 won't boot even with battery out or in or p
Can you enter to Bios? if it boot and doesnot load to windows, could be your windows is corrupted or your hard drive is died, but if it doesnot boot at all, this could be not enough power.
Oct 14, 2009 | Dell Latitude D600 Notebook
Dell C600 No boot, all lights on exept battery charge indicator
u may need to source a main board..and change it..hope it's still under warranty ...
May 22, 2009 | Dell Latitude C600 Notebook
No battery working
If your batterry is 3 years old u have to replace it. Its not charging properly
Apr 10, 2009 | Dell Latitude D600 Notebook
DELL Latitude D505
Have you tried the other fix? It often times works.
Remove the battery AND the power cord.
Hold the power button for 10 seconds.
Now plug in the power cord.
Magic should happen
Feb 27, 2009 | Dell Latitude D505 Notebook
Dell D600 Wont turn on sometimes.
Reseat the harddrive (take out the screw and slide it in and out)
You can run diagnostics, during startup (just after Dell logo) press F12,then select Boot to Utility partition, or Diagnostic partition.
It may reveal you issue
Hope this helps
Feb 04, 2009 | Dell Latitude D600 Notebook
D800 will not even boot
remove the battery from the system and try to power on the System with the AC adapter connected. its only to check whether the system is receiving the power .
Also press the Fn key holding it down press the power button and release both the buttons , look for the LED codes and do let me know abt it
Apr 21, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
