Question about Siemens Refrigerators
I want to permanently remove an alarm from a siemens fridge. Not disable it, not stop it, just remove the speaker that is making the noise. The problem is that i dont know where to locate it. Help!
I don't know the model :(
    New Friend:
  • 17 Answers
The model number should be just inside your fridge door - look on the inner threshold - there is almost always a sticker there.
Other than that, you could find the sensor and override it - for example, if it's an open-door sensor and it's a lever-switch, just tape the lever down. Personally, I wouldn't do this because my kids would probably leave the door open and cause the compressor to burn up from running too long.
However, find your model number and search for a service manual. From there, you'll be able to track down the buzzer - I suspect it's behind the panel for the ice/water dispenser, assuming it has one.
Posted on Apr 07, 2015
How do i stop the alarm on my siemens fridge
clean the the rubber seal if the alarm keeps going off as the seal is not sealing correctly. hot soapy water clean it all even in the gaps. should stop then.
Jun 12, 2018 | Cars & Trucks
My siemens frdge is making rattling grrrrr!!! Noise evey now and then.recently it makes noise around 3am then it stops.what should i do?
hi, Lets do some simple things that you can do EZ.
1. Unplug keep doors closed.
2. Pull out fridge be careful of the water supply line for ice maker.
3. Remove the cardboard or metal back panel.
you will be able to access the fan and you will need to vac all the dirt and clean the fan blades with degreaser
Shoot WD 40 on fan shaft and rear of fan motor.
Vac and clean the cooling line grid on the back of fridge.
4. If it is still nosey defrost it unplug 12 hrs clean drip pan under fridge and M/T. Plug in and let it get cool. This will de-ice the crossovers.
Mike
Mar 12, 2018 | Cars & Trucks
How do I turn off the alarm on the model #7-4837D
To silence the alarm momentarily
Press SNOOZE. The alarm will sound again when the snooze period is over.
To stop the alarm
Press ON/OFF. Then, the alarm will be on the following day at the same time.
To disable the alarm permanently
1. Press CANCEL button
2. The WAKE indicator will be flashing.
3. Press WAKE MODE button within 3 seconds
to deactivate the alarm function permanently.
http://manualzz.com/doc/2137875/ge-7-4837-clock-radio
Feb 07, 2018 | The Audio Players & Recorders
GE Profile fridge model PFE28RSHHSS. All sound has stopped working, so no open door alarm, or sounds for any other function. Other than that fridge works perfect
The speaker is located on the dispenser board. It is told when to make noise for the door alarm by the main control board. There is no test to determine which board is bad. There is nothing to measure on the comm cable between the two. Are there any other issues going on with it? Sometimes some other functions start to blink out and can point you to which board is bad.
Aug 03, 2016 | GE Refrigerators
How do I permanently disable a DEI Automate car alarm on our 1999 Acura Integra.
Just remove it. It shouldn't be too hard, take all the parts and harness out, reconnect any cut wires and wrap any exposed wires with electrical tape.
May 31, 2015 | 1999 Acura Integra
How do I disable or remove door alarm?
The alarm is operated by a magnetic switch connected to the control board. If you can find it you can bridge it out if it's a make switch, or disconnect it from the board if it's a break switch. Find the control board and the connection first. ***WARNING*** the switch also operates the internal fans and removal of the feature will increase your power bill and make the fans run permanently. Does the alarm come on as soon as the door is opened?
May 03, 2014 | Samsung RF260BEAEBC 26 Cu. Ft. French Door...
The charge light don't work
LOL LOL LOL HIHIHI my charge light don`t work ether do you know what i`m referring to because i don`t know what your refining to, maybe you should be more forthcoming with your make modell and other
Oct 23, 2013 | Electronics - Others
Stalls when stopping at a junstion
right so we know it is a renault & we know it is a 2001 model & we know it stalls at junctions but......... we don't know what model of car or van or minibus or vehicle it is!!!, this is all relevant as all models are different & It could be many things.
Sep 13, 2012 | Renault Kangoo Cars & Trucks
High temp alarm goes off in the middle of the night even though temp feels fine
Got the manual? The alarm should be able to be just displayed, with the buzzer muted.
May 16, 2012 | Viking Refrigerators
I bought a RCA remote and i don`t know how to used
Google the name and model of the remote and put instructions behind it....If you don't know the model, it may be under the battery lid (either inside or on the lid itself). If its not there, you can go to google images and type in rca universal remote and find one that looks like yours and it will tell you the model. I have done it before.....
Mar 13, 2012 | RCA RCR815 Remote Control
Refrigerators Logo
204 people viewed this question
Top Siemens Refrigerators Experts
marlin siecinski
David Ellis Rhea
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
