Question about Karcher K 5.68 M 2000psi Electric Pressure Washer
There,s no electric power.
I plug it on there is no power at all . I check the fuse is ok. How can i detect the problem?
MY LG TV HAS JUST LOST THE PICTURE AND THE POWER LIGHT HAS GONE OUT.PLUG FUSE IS O.K.
Many electronics devices have fuses inside. Also power supply circuit devices can, of course, fail. If you want to open it to look for a fuse, there is usually a warning on the back about that. . . I have seen a set that went out as you describe, opened it, found a bad fuse. Replaced the fuse and the set has worked for years since.
Oct 20, 2014 | Televison & Video
My is73 system will not power up . the 2 fast blow fuses are ok
Hello, welcome to Fixya!
Your receiver is having a power fault because it is not switching on. The receiver might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the receiver.
If plugging into another power outlet doesn't power it on then it confirms that the receiver is having a power fault.
When electric current comes from the power outlet into the receiver, it goes straight into the power supply board which then circulates the current into the unit. So if the receiver doesn't power on, the first thing is to make sure there is power entering into the receiver.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Jan 05, 2012 | Audio Players & Recorders
Ok, I have recently been the fortunate one in my family to be given a Philips proscreen 4600 b projector. The only problem, so far, is it will not turn on, at all...think that's why it was given to me...
Your unit is having a power fault because it is not switching on. The unit might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the unit.
If plugging into another power outlet doesn't power it on then it confirms that the unit is having a power fault.
When electric current comes from the power outlet into the unit, it goes straight into the power supply board which then circulates the current into the unit. So if the receiver doesn't power on, the first thing is to make sure there is power entering into the unit.
Regards.
Jan 04, 2012 | Philips Televison & Video
No power. outlet is good, microwave plugged in. no lights, no power, nothing. does this unit have a power supply that might have gone bad?
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Regards.
Nov 06, 2011 | Hotpoint RVM1435 Microwave Oven
The fuel pump in my 95 bmw 318 packed in,so i got new one,but now der seems to be no power going to itrelays,fuses etc..all ok,tested fuel pump of batt an it workin fine.any suggestions??
you have 2 electrical plugs...only one wire should have power(cant remember which one) if there is no power. then check the fuse if the fuse is ok...then check the relay by swapping relays they should be the same or at least work! if still doesn't work you might have to change the panel...where the fuses are!!!
Mar 21, 2011 | 1996 BMW 318
Driver side power window doesnt work
Its possible, check underhood fuse box, the position 6, 60AMP for Power Windows
Other details can find in the Ford-Explorer-Owners-Manual (page 187 and next)
If the fuse is OK, take off the trim panel to check the windows motor, windows switch and wires.
Hope helps (remember rated this).
Jul 23, 2010 | 2003 Ford Explorer
No electrical power to anything - even dome light.
Check battery and chassis earth connections are ok.
Check for 12v power at the fuse/power disrtribution fuse bus; - if no power there, trace circuit wiring back to battery.
Jul 12, 2009 | Chevrolet Blazer Cars & Trucks
No electrical power to any of 4 power outlets in 02 Toyota Sequoi
In the fusible link block, if the 120A ALT FUSE is OK and in the instrument panel junction box if the 15A CIG FUSE, the 7.5A RAD 2 FUSE, the 15A POWER OUTLET FUSE and the ACC RELAY are OK, there has to be a wiring fault.
May 07, 2017 | 2002 Toyota Sequoia
Lower Brake lights dont go after we plugged trailer on
does it go back to normal with out the trailer connected. as both mine when the trailer is detected on the wiring it turns the abs to mid setting. , as it cannot calculate the extra load. also the trailer loom can put more drain on the electrics and there is a voltage reader computer built into most vehicles this is what detects a blown bulb. check the fuse connection to the fuse and the box. in the fuse box. a weak fuse or fuse holder can make the bulb blow.
Jul 02, 2017 | 2006 Chrysler PT Cruiser
Karcher K 5.68 M 2000psi Electric Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
