Question about Pioneer Audio Players & Recorders
Hi! I have a Pioneer PL 530 record player went on the fritZ!! Wont shut off?
My record player was working great and all of the sudden the arm won't release back and the the turn table will not stop spinning. I have to unplug it and manually work the arm. All of the automatic functions don't work, the stop button, start, and repeat button don't work. I've taken it to a local record shop to get checked out and they set up the speed and needle pressure but are not sure whats going on with it. Any help would be much appreciated! Please i really loved this player too!
    Sergeant:
  • 357 Answers
Go to the vinylengine website. There are forums full of experienced users to help
Posted on Feb 23, 2016
  • 42 Answers
SOURCE: BSR turntable arm slides across record
There can be a number of reasons for this.
Have you checked that the stylus tip has not broken off? this is a common cause and will require a new stylus.
Posted on Jan 24, 2009
  • 104 Answers
SOURCE: Adjustments on Technics SL-B2 Automatic Turntable
the pitch is just the speed, adjust to your liking.
"How do I adjust tracking pressure and anti skate?
If you are lucky enough to have these two adjustments here's how: Move tracking force counter weight till needle suspends/hovers above record. then rotate numbers to zero. (this is zero grams pressure on record) then rotate weight AND numbers to recommended tracking pressure for your needle usually 1.5 to 3 grams is average. Then rotate anti skate to be equal. That should get you there. If you still have adjustment related distortion then it may be time for a new needle.
NOTE: Anti skate is adjusting side to side pressure WITHIN GROOVE of record. Tracking pressure is how hard the needle is pushing down inside the groove." from
turntableneedles.com/FAQs_ep_33.html
lots of crackles are caused by crummy records and needles. to some small degree are unavoidable no matter what, but above all the records must be clean.
someday the manual may show up for free here
http://www.vinylengine.com/library/technics/sl-b2.shtml
Posted on Feb 11, 2009
SOURCE: Where to get 12 volt power supply for Pioneer PL-203AZ Turntable?
+ is on center pin, and the current consumption is low, not more than 200mA. A 12V wall-wart will do fine.
Posted on Dec 23, 2009
  • 4234 Answers
SOURCE: pioneer pl-570 turntable around 1996 model .
With a tabel of this vintage, any grease has probably turned to glue. This unit requires a complete overhaul. The old grease needs to be removed and the unit regreased. There should be a small microswitch that controls the on/off function. This switch can be dirty or the lever that makes it work can be stuck with the grease. Without seeing the actual unit, it is hard/impossible for me to tell you exactly the problem. I have done 100s of units of this vintage and can state with confidense that the overhaul/cleaning will return this to full function.<br /> <br /> Dan
Posted on Aug 19, 2010
  • 4 Answers
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Posted on Sep 20, 2010
Hi! I own a Pioneer PL-333 TT, it hasn't been used in a long time and there're two minor "problems". First is the cartridge touching the discs, but I can flex the head of the arm so it doesn't. I mean, the...
Look on the platter for somekind of location pin that the record will hit to tell the player what size record you have. Some of the more expensive players have a light near the stylus that shines down and by reflection of the light back up to the stylus will tell the player what size.
Jan 06, 2015 | Audio Players & Recorders
Some of the lps i buy do not fit the table. for instance, usually the edge of the record scrapes the arm stand. Now though, i have a record that wont even turn because it seems too wide. any idea?
I had the same problem, at first I would just gently file down the edges of the records with a nail file, but when they got too many I decided to tackle the root of the problem and used a sharp blade to shave off some of the plastic of the arm stand, about 1 mm. No problems since!
Aug 25, 2012 | Pioneer PL-990 Turntable
Can't find replacement cartage for Pioneer PL-200
Try a computer search. There are sources out there
Jul 29, 2012 | Pioneer Audio Players & Recorders
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Jan 04, 2009 | Audio Players & Recorders
Pioneer PL-570 turntable (c.1973)
Yes first check is that the Gnd wire from your turntable is connected to the Gnd (ground) post at the back of your amplifier with a good clean tight connection.
If the problem persists, check ALL your hi-fi components mains plugs for earth connections including your turntable, then remove the earth connections on all but one component so that you are left with only item earthed.
What does sometimes cause problems is if 2 or more hi-fi separates are earthed and connected to each other the earth cables along with the hi-fi interconnects form an inductive loop that picks up interferance such as mains hum etc.
Regards John
Sep 16, 2008 | Pioneer PL-990 Turntable
238 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
