Question about BT Lands Phones
Since connecting to BT Infinity, why does my 4500 base unit emit a whistle louder for incoming calls?
I'm not sure if I can make outgoing calls. My cable connected phones work OK and report missed 4500 calls by dialling 1471. The 4500 doesn't record answerphone messages. Is the 4500 incompatible with BT infinity?
  • 2 more comments
  • Raymond Geoffrey Noxon
    Raymond Geoffrey Noxon Apr 07, 2015
    I'm answering my own question!
    First, when I tried to make a call I could not.
    Then, after removing the mains supply and reconnecting, all was back to normal.
    I only had to reset date & time, something I have to do after a power cut!
    Raymond Geoffrey Noxon Apr 09, 2015
    The FIXYA team emailed to say: no answers so give more detail, BUT see my own answer (above)!
    Raymond Geoffrey Noxon Apr 10, 2015
    See my original further comments: 1) I found my own solution; 2) I had already phoned BT, they were not helpful!
  •  johnny rebel
    johnny rebel Apr 10, 2015
    so you are all set?
    Top Expert:
  • BT Master
  • 10,875 Answers
Call bt infinity
Posted on Apr 09, 2015
Display on base unit is blank - handsets display "Searching". This is a DECT 6.0 system.
Please provide me with your model number so that I can help you.
Jul 29, 2015 | Uniden Lands Phones
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
BT 4500 cant answer messages from base only phone help please
Master unit has On/Off answer button. Select option you require.
The extension units do not have a message facility.
Nov 12, 2014 | BT 4500 Cordless Phone - DECT - Satin...
How can I get my KX-TGE263 corless phone to connect
Please refer user guide available at the attached link.
I am assuming you have trouble answering incoming landline calls from the phone and there is no problem with making outgoing calls on landline. Also I am assuming you are using cell phones and do not have any panasonic handsets.
First thing to check is whether you can answer using the base unit or not. From there on you will have to then check if the cell units are actually working with the base unit. Follow the bluetooth setup instructions and make sure your cell phone is compatible.etc. http://service.us.panasonic.com/opermanpdf/KXTGE260-MUL.pdf
Aug 10, 2014 | Panasonic KX-TGE273S Link2Cell Bluetooth...
Bt freelance
Try pressing the mute button?
Nov 07, 2013 | Lands Phones
Telstra V580a cordless phone not working.
Try disconnecting all power to the base stations and the batteries in the handsets for a few minutes.After reconnecting power it may take a few minutes for the units to reconnect.
Good Luck
Doc
Aug 14, 2009 | Lands Phones
Unit does not make outgoing calls nor receive incoming calls. Display seems OK but tiny vertical bar top RH corner doesn't flash 9should it?). Unit is fully charged. Trying to call IT from cellphone gives...
Friend i think u r cell phone setting are mess up
so please go to ur cell phone setting and go to security and then try to find restriction menu and then turn of it if u find it then
u got
three options like
outgoing call
incoming call
messege
phone book restriction
so set it unselect
Jul 22, 2009 | Cell Phones
Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
Apr 29, 2009 | Philips VOIP8411B/37 IP Phone
Kenwood KDC-BT838U -- Low audio on incoming phone calls only.
Patrick -
I have the reverse problem.  Callers can hardly hear me. I saw a setting in the headunit that allows you to specify where the audio plays for incoming calls.  You can choose the Left Front Speaker, the Right Front Speaker or Both.  Check the manual and make sure its set to both.
Regards, Charlie
Feb 02, 2009 | Kenwood KDC-BT838U Car CD Player
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
Lands Phones Logo
137 people viewed this question
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
ptpumpman
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
