Question about Denon Audio Players & Recorders
How do I reset my Denon AVR 1709? - Denon Audio Players & Recorders
    Genius:
  • Denon Master
  • 1,054 Answers
With power off - press and hold the "INPUT MODE" & "SPEAKERS" buttons and press power. All display segments should blink. Let go of buttons and reset is complete.
Posted on Apr 07, 2015
SOURCE: connect denon 1709 to my tv
I will assume that your TV is an HDTV capable unit. Since I also would assume that the Denon AV1709 is properly setup in your listening room/Home Theater. You will need to purchase one HDMI cable from the Denon to the TV input. This cable must be long enough to go from the Denon to the TV with length to spare. The more money spent on a better quality HDMI cable will pay dividends on how much better the screen will appear. On the back of the Denon is an HDMI output labeled "Monitor Out" that the new cable will go into, and the other end of the cable will go into the TV input labeled HDMI. On the remote I would search for a button labeled "Input" or "Source" and on the screen I would look for the input that would reflect the same input you put the HDMI cable into in the TV. If your TV doesn't have HDMI inputs see if it does have "Component input" on the back The information will be similar but will reflect the different Input and Outputs you may need to use. The cables will be more complicated but they are color coded just for you. Red goes to Red, Blue goes to Blue, Green Goes to Green. Enjoy Re-Post if you need further information.
Posted on Sep 17, 2009
  • 137 Answers
SOURCE: denon avr -1709 how
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Posted on Apr 19, 2010
  • 6771 Answers
SOURCE: My Denon AVR-1709 was professionally
This is a case where the audio output ic's have failed, you describe a popping sound which is a classic sign of total audio collapse. Since this was a professional installation, I recommend a top of the line audio technician with an estimate in mind.
Posted on Jan 07, 2011
Testimonial: "it's bad news, but it is the truth. thanx for your help!"
bobhifi
  • 635 Answers
SOURCE: hi, i have setup my
After you attempt to turn on the Denon if it turns off after 4 seconds and the standby light starts blinking you have an internal fault and it needs fixing by a professional.Try disconnecting all the speakers and turn it on to confirm any errors on your part.
Posted on Mar 09, 2011
  • 256 Answers
SOURCE: what will factory reset avr 1709 fix
It will not fix any problems with it, It just sets it back to the way it was before you set it up.
Posted on Dec 05, 2012
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
H/p input on display clicks on and off
Need to either unplug the cable to the headphone jack board (if you don't want to use the headphone jack), or have the jack replaced. This is a common problem with these models. The is a short in the headphone jack that makes the unit intermittently think there is a set of headphones plugged in even when there isn't.
Aug 14, 2013 | Denon AVR-1709 Receiver
What will factory reset avr 1709 fix
Dec 04, 2012 | Denon AVR-1708 Receiver
Denon Receiver keeps switching between H/P input and speakers
The problem may be dust in the headphone jack
http://blog.adamnash.com/2010/10/01/solution-denon-av-receiver-avr-1410790-with-no-sound/
Jun 17, 2012 | Denon AVR-1709 Receiver
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
DENON 1709: The sound is OK when STEREO is setting. Using 5.1 STEREO or MUSIC or CINEMA setting all the speakers are working, except Front Right. I check the volume for each speaker and set it up to the...
The Stereo setting does not use any digital processing and likely avoids the decoding board completely. From your description, either the signal is not being decoded properly or the right channel signal path is being interrupted somewhere. Without taking measurements inside the unit, I cannot tell for sure where the problem lies. Careful examination of the processing board is required here. Take the unit to a repair shop for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair.
Dan
May 29, 2011 | Denon AVR-1709 Receiver
I have a Denon AVR-391.Now it is starting to stop functioning. The set will work then after a while I can not operate any of the commands via remote or manually. The set will not turn off nor am I able to...
If you have had this unit for a while I would try vacuuming or blowing it out because it sounds like the issue you are having is due to heat building up in the unit. Also make sure you have adequate airflow around the unit in other words make sure you have at least 2-3 inches of clearance on all sides and nothing sitting on top of the unit.
Apr 11, 2011 | Denon AVR-1709 Receiver
My Denon AVR-1709 was professionally installed. It lasted less than 2 years, then the speakers started popping, then a few days later there is no signal to any of the 5 speakers or subwoofer. same for all...
Jan 07, 2011 | Denon AVR-1709 Receiver
Denon avr -1709 how do i get it reset to factory specs
Mar 21, 2010 | Denon AVR-1708 Receiver
Connect denon 1709 to my tv
Sep 16, 2009 | Denon AVR-1709 Receiver
117 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
