The power indicator is on. Why doesn't the TV turn on?
    Top Expert:
  • Televison & ... Master
  • 44,949 Answers
The power supply may have failed.
Posted on Apr 07, 2015
I replaced the lamp in my Sony E50A10 and the tv still doesn't power up.The indicator flashes red.Any ideas?
if its the lamp indicator flashing its an issue with the lamp. If the lamp is new I would double check to see if its making contact completely when its slid in often the pins can get bent slightly. If it were the ballast the power indicator would blink 5 times.
Feb 09, 2013 | Sony Wega KDF E50A10 TV
After replacing all capacitors on the power supply board,Tv still doesn't come on
if only a blinking indicator at the tv panel that was mean has an error detected by the main board. if no any power indicator then you have been already replaced bulging capacitors but still won't turn on. at this time you will need to have voltage checking using a digital tester, if their is an output voltages at the power supply board.
Jan 18, 2013 | Samsung LN46A530 46 in. LCD HDTV
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
Why doesn't my magnavox led tv turn on?
if just an stand by indicator at the front panel check for bulging capacitors at the power supply board.
Sep 30, 2012 | Funai Magnavox 19" Class 720p 60hz LED TV...
Turns on immediately turns off
check for shorted component parts at power supply board like bridge type diode and FET transistor. if those are good, disconnect the connectors that supply going to inverter board and then turn on the tv unit if the light indicator at front panel stay and 24v supply doesn't drop which mean the inverter board was the problem of suddenly turn off.
Sep 01, 2012 | Samsung LN19B650 18.5 in. HDTV LCD TV
VIZIO VS470 WON'T TURN ON
do you mean the power indicator at the front panel doesn't light.ok this kind of trouble is in power supply section since the stand by doesn't work. the first place to be check is the fuse if blown. if blown with darkened color that was an indication that has other component part that get shorted. at this time you will need a proper trouble shooting using the a device like a digital or analog tester. if you don't have enough idea on how to do the job and necessary tools, just send it to the trusted service shop to fix the problem.thanks for using the fixya.
Aug 13, 2012 | Vizio VO370M LCD TV
My sony kdf e50 12u wont turn on red light blinks twice
Your TV is giving you a code, something is faulty in the system, usually 2 blinks of the red light indicates, Load on power line is shorted. I also would check the bulb also to make sure it doesn't need replacing.
Jun 22, 2012 | Sony Televison & Video
I have a ge universal remote and a panasonic tv but i dont have the directions on how to program it or what the codes are to set it up. i need step by step instructions.please help
There are two types of GE universal remotes. Does your remote use the 4-digit code or the 3-digit code?
These codes listed below are not for combination TVs (TV/VCR, or TV/DVD). If you have a combination tv, see the appropriate code list here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
The 3 digit codes for Panasonic TVs are 003, 054, 055, 062, 070, 148, 149, 170, 171, 374, 381, 437 . If you have an LCD or Plasma Panasonic only try 170.
The 4 digit codes to try for Panasonic TVs are 1182, 0171, 0148, 0054, 0170, 0062, 0374, 0381, 0437, 0950, 0003, 0070 .
Next to program the remote: Turn on the TV manually. Press and hold the Code Search or Setup button (depending on your remote). Hold the button until the indicator light comes on and then release it. Then press and release the TV button. Type in the first code for your remote and TV combination. The indicator light should go off. Then point the remote at the TV and see if the TV turns off. If it doesn't, repeat the above steps. Once you have a code that seems to work, check if the remote controls all of the functions that you need (based on the available buttons on the remote). If you have a code that turns off the TV but doesn't control other functions, continue trying other codes.
There is an option to search through all of the codes of the remote to program the remote. Press and hold the Code Search or Setup button. Release the button when the indicator light comes on. Then press and release the TV button. Now press and release the Power button on the remote repeatedly and wait until the TV turns off. Do this slowly (pressing the Power button every 2 seconds). When the TV turns off, press Enter on the remote to save the code. Then test the remote. If the remote doesn't control all the functions of the TV that you want it to, then repeat the search.
Please note that the codes in most universal remotes are limited to those for devices released 6 months or more before the remote was programmed. If your remote is older than your TV, then you may need a new remote.
I hope this helps.
Aug 06, 2011 | GE JASRM24912 Remote Control
I have two Behringer Eurolive B415DSP speaker, one of them stopped working out of no where. To my best knowledge, the problem is that it doesn't turn on. I had the Fuse check already and thats not the...
This is alimentation fault of the amplifier inside the box. Dismount the amplifier block and take a look first if there are some burned pieces. If it seems all ok, better bring it to a electronics/ tv service center.
May 18, 2011 | Behringer Eurolive B415dsp 600w 15" PA...
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
