Why won't my old Paloma pg-820s switch off?
    Top Expert:
  • 75,571 Answers
What is this? Rat Trap?
Posted on Aug 29, 2016
2 Suggested Answers
  • 5245 Answers
SOURCE: My Paloma pg-711fr is turning itself off and error
Copy following link for error codes and Rheem-Paloma tankless troubleshoot.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#error
Add a comment and say if this is new installation.
Call Rheem and hear them tell you to call the tankless installer, or hire local service technician to check your tankless computer that heats water, and catch up on required monthly and yearly maintenance. For example cleaning burner and flame rod, or replacing bad flame rod, or installing correct gas line, or checking gas pressure etc.
Fix any tankless problem yourself, any brand tankless, same day for $385, by replacing 1 part: the whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Do not install tankless.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jul 21, 2013
I have a paloma tankless water heater (no sure how old) currently renting (landlord useless). Code says C7 12. What is this?
Probably a flame failure code. This is a Rheem product. Go to the Paloma web page and track down the code. Just google it.
Mar 11, 2017 | Water Water Heaters
I have a paloma ph6dp water heater that hasn't
You have an old tankless computer and it won't work?
What would you do if you had old laptop computer that didn't work?
Copy following links for possible resources including required yearly maintenance so tankless computers can last 4-6 years before needing replacement:
Gene
h
Sep 07, 2013 | Water Heaters
My Paloma pg-711fr is turning itself off and error 12 comes up
Jul 21, 2013 | Water Heaters
I have a Paloma PTG 42 PVN Cold water turns unit off
Inside the unit there is an electrical " gap switch " like an off/on switch, if this is not set right to yr water pressure it will not work correctly. Take the front of the unit off, find the switch which is usually in the front area at the bottom where the cold water goes in, and ajust the screw on the side, suggest you open it a 1/2 turn at a time to increase the flow valve, and see if that is yr problem. cheers
Aug 01, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
How can I order the PCB schematic and electronic PCB
Check your old board for bad capacitors.
Mine had one bad capacitor. 470uf and 25volts
Hard to replace capacitor because the board is seal.
But can done with some solder knowledge.
Drill hole behind bad cap, 3/4 inch wide. desolder the old and replace
with a same rating cap. Seal hole with tape and reinstall.
Nov 29, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Sanyo DP46841 TV and would like to hookup wireless speakers since i am hearing impaired. Can this be done and if so what are the best system to use? Jim
The Sennheiser Set 820S is a TV/music listening system specially designed for hearing aid wearers. With roughly a 100 foot range, Set 820S users can leave the room while still being able to listen to a TV program or music. Enhanced with radio frequency (RF) technology for a larger coverage area, users won't need to worry about missing a word of the program or song. The Set 820S consists of the 820 RF stereo transmitter and 820-S RF stereo bodypack receiver. The transmitter connects to a TV set or hi-fi system; the receiver can be clipped to clothing. The receiver can be coupled with an induction neckloop (sold separately) (hearing aid must have a t-coil), direct audio connection (to cochlear implants or BTE hearing aid) or Sennheiser headphones with a 3.5mm jack. Two year warranty. · Bodypack receiver · RF wireless transmission · Stereo or mono operation · Quick charge feature · High SPL (125dB) · Approximately 100 foot range · Maximum volume and bass response adjustable by hearing professional
http://www.mcssl.com/store/familyhearingcare/catalog/product/7f146beca0684d65a142df331ef59c00
wireless speakers are also available ........ but you may not hear 100% of sound............. click above shown link.... you will find many similar products ...... you can check thier price , features, etc & then you can finalise the one that suits you best ..............
Aug 09, 2011 | Sanyo Televison & Video
I have a Paloma PTG-74PVN and I ain't getting any hot water and its showing c2-11 error code. How can i fix this problem
could be overheat stat or fan check the little hose at the fan area for pinhole next choice diaphrapm valve then micro switch best of luck
Oct 23, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a 2 year old paloma tankles heater i get a c4 76
Make sure the wire connecting the thermostat to the unit is 18 gauge solid copper thermostat wire
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Heating & Cooling Logo
192 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
