pull two bolts from bottom leg pull off imp is inside round silver plate on bottom of drive shaft two screws pull off put in turning clockwise as you install put back together good luck
Look up Saving Old Seagulls and IGNORE the rubbish that some jokers have posted (Seagulls don't have an engine check light!) Most Seagulls have constant mesh gearing. Lubrication is by 140 grade gear oil. If you cannot get this, ST90, EP90 or Hypoy 90 will do, the important thing is to use a heavy oil NOT GREASE not even the semi-fluid grease used on weed-wackers (they have ball bearings but a Seagull has bronze bushes) The "clutch" on some Seagulls is basically a fork which puts the gears out of mesh, there are no clutch plates. Good luck!.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
