Is the clear cast antenna worth $88 - Televison & Video
    Top Expert:
  • 10,875 Answers
Posted on Apr 07, 2015
I no longer have cable on my tv and tried to hook up a antenna to my RCA 32V420T tv. however i can't get a clear picture on the tv?? what should i do??
Hi Diane
If you have had cable for a long time the chances are that your antenna is the old type and not compatible with todays digital signal. It might by worth investing in a new antenna.
Feb 01, 2017 | RCA Televison & Video
A antenna casts a shadow that is 16 yards long. A water tower near the antenna casts a shadow that is 8 yards long. If the antenna is 30 yards tall, how tall is the water tower?
Hi Karla
First off it is 'An antennae'. If the second word starts with a vowel, you use 'an' rather than 'a'. An Orange, an Apple, an Emu etc.
To your homework.
The shadow for the antennae is 16/30 of its height. Therefore the same ratio, or length of shadow to height of object applies.
The water tower is 8/?
Divide 30 by 16, and multiply that figure by 8.
Nov 14, 2016 | Cameras
Is Clear-Cast TV micro antenna device legitimate?
From a basic standpoint, yes it is legitimate and it will work. How well it will work really depends on a number of things. it depends on where in your house you place it, how far you are from the transmitters and what your house is made from. The structure can interfere with reception.
As a general rule, outside is better than inside for over the air digital reception. Higher is also better, so place any antenna as far up on your house as you can outside, next go to the attic space if you can;t mount it outside. And even if you are in a condo or HOA , they have to allow you to mount a TV antenna on your house outside under FCC regulations.
Nov 08, 2014 | Televison & Video
Need to see a image of how plug wires go on a 1992 oldsmobile 88 royale
Intake manifold normally has firing order cast in, or get a shop manual. The hard part can be finding which should be #1, especially if you have had the distributor removed. Use compression gauge to find TDC compression stroke on #1 and see where rotor is pointing.
Apr 28, 2014 | 1992 Oldsmobile 88
My daughter has a 98 olds 88 i removed the stock stereo and put in a pioneer cd player but i didnt see any wire on the stereo side for the elec. antenna i was wondering how i can wire it to work
Most aftermarket pioneer cd/radio decks have the electrical connector for the antenna that I've seen.
Is this a cd only deck, or does it have radio functions?
Did you use a new harness wiring adapter to get the pioneer radio to work with the old harness?
There should be a color coded set of wires for the power antenna on that. And, then the Pioneer radio should have wires that were labeled for the power antenna.
Oct 08, 2010 | 1998 Oldsmobile 88
Is there a fuse for a 1985 delta 88 power antenna
Depends. Is this factory or aftermarket? If factory... just the standard fuse in the fuse panel under the sah. Should be a red 15A. If aftermarket... there should be an inline fuse on the orange wire coming from the antenna.
Sep 01, 2009 | 1985 Oldsmobile Delta 88
Power antenna on my oldsmobile 88 will not shut off and the antenna is up it even runs without the ignition on
Fault is within the power antenna unit. Needs replacement. If you dont mind the mast being up, it can be disconnected , in order to stop the motor running. Car washes will damage the mast in the event it stays up. Hope this helps.
Apr 23, 2009 | 1988 Oldsmobile Delta 88
Power antenna. 1986 olds delta 88
Obviously if fuse panel has a power antennae fuse, simply pull it, otherwise you may have to get to connector at motor by removing part or all of sheild in wheel well to access it in some cases. Only other option would be to remove radio from dash & disconnect antennae power wire from radio. Don't forget you want it up before disconnecting if you can.
Jan 30, 2009 | 1986 Oldsmobile Delta 88
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
