Question about Facebook Apps
How do i fined my share holding - Facebook Apps
I wish to liquidate usa share certificates who will do it
A stockbroker can handle this but only if a buyer can be found. Otherwise, they will have to be declared a loss.
Nov 06, 2013 | Computers & Internet
I can not get my kodak hero 5.1 printer to work on my windows xp 64 bit
Turning sharing on or off
The first time you connect to a network, you'll be asked if you want to turn on sharing between PCs and connect to network devices such as printers. Your answer automatically sets the appropriate firewall and security settings for the type of network that you connected to. You can turn sharing on or off at any time.
To turn sharing on or off
  1. hh_ppeic.pngTap or click to view available networks.
  2. Press and hold or right-click the network you're connected to, then tap or click Turn sharing on or off.
    435600ef-5a98-4568-bfa2-28d51981b1e3_13.jpgMenu used to turn sharing on or off
  3. Do one of the following:
    • Choose Yes, turn on sharing and connect to devices for home or small office networks, or when you know and trust the people and devices on the network. This setting allows your PC to connect to devices on the network, such as printers.
    • Choose No, don't turn on sharing or connect to devices for networks in public places (such as coffee shops or airports), or when you don't know or trust the people and devices on the network.
      Notes
      • Turning sharing on prepares your PC for sharing files and devices on a network. For more information about sharing with other people on your network, see Sharing files and folders on a network or a shared PC.
      • The network sharing setting is only available for WiFi, Ethernet, VPN (non-domain) and dial-up (non-domain) connections. It's unavailable for domain networks. On VPN or dial-up connections, you must connect to the network first, then press and hold or right-click the network name to change the network sharing setting.
      • Turning on sharing changes your firewall settings to allow some communication, which can be a security risk. If you know you won't need to share files or printers, the safest choice is No, don't share or connect to devices.
      • Choosing No, don't turn on sharing or connect to devices blocks the following applications and services from working: PlayTo, file sharing, network discovery and automatic setup of network devices.
About network discovery
Network discovery is a setting that affects whether your computer can see (find) other computers and devices on the network and whether other computers on the network can see your computer. It's one of several settings that are turned on when you turn on network sharing. You can turn network discovery on or off independently of network sharing, but we discourage this. Here's why. If you're connected to a network in a public location and you decide to turn on network discovery but leave network sharing turned off, the network discovery setting will be on for every public network you connect to from then on. This wouldn't be safe. That's why we recommend using the network sharing setting instead.
However, if for some reason you need to turn network discovery on or off independently of the network sharing setting, here's how to do it:
  1. hh_ppeic.pngTap or click to open Advanced sharing settings.
  2. Tap or click the chevron 7d2e0f87-bcfb-44a3-8422-5c9353bcde11_89.jpg to expand your current network profile.
  3. Tap or click Turn on network discovery or Turn off network discovery, then click Save changes. 1f9463c2-c968-47bf-9b4d-939c5d1af477_70.jpg You might be asked for an admin password or to confirm your choice.
Jan 07, 2012 | Kodak Office Equipment & Supplies
Used to work fine until router was replaced. Now, network can't find printer. Samsung CLP315w printer, Windows 7 and XPpro on 2 laptops.
Hello!
You must not have configure your printer to be shared that is why you can't find it in your network.
To share printer:
- go to Control Panel
- open Printer and Faxes
- select or right click your printer and click sharing
- on the Sharing menu, click share printer (that's it)
but if the problem still occurs, try checking your Windows Firewall settings, to do this:
- open Windows Firewall
- at WIndows Firewall menu, click Exception tab
- in Exception tab, try to check if Printer and File sharing is enable.
Note: to find what are shared on a particular computer:
- at RUN command, type the ip address or computer name
(\\10.0.0.23 or \\samuelcomputer)
Hope this solves your problem.
Jul 31, 2010 | Samsung CLP-315W Laser Color Printer
How do i use it? I connect both computers but then cant figure out how to actually execute the sharing of data.
Well you have to share something from both the computers.
Right click on a folder or a file and go to Properties- go to the Sharing tab, and where it says Network sharing and security, thick "Share this folder on the network".
If you do this for the first time it should be a wizard. Remember you have to do this thing at both of the computers. And another thing: be carefull at the workgroup. It would be better if two computers would have the same workgroup
You will see the sharing from the other computer: open a Windows Explorer- go to My Network Places- Entire Network and you should see the folder shared from the other computer.
To see if you succesfully shared a folder check the icon of the foloder. If it has a little hand, that holds the folder, than it is shared
If you need further assistance, post a comment.
Thank you for using FixYa
Mar 22, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I cannot set up my home network to share files and computers now
If you want to share a file on your network right click the file select properties, in the sharing tab check share this file. Make sure all you computers have the same workgroup name.
Dec 01, 2009 | Computers & Internet
Hook Everio camera to JVC share station - will not make dvd -
First, make sure that you are using ONLY DVD-R discs. And the cheaper, the better. For some reason, the more expensive ''name brand" discs do not work as well. If that doesn't work, try cleaning the laser. But make that your last resort.
Jan 13, 2009 | JVC Everio Share Station DVD Burner Burner
Printer sharing problems
Can you see the printer from the networked computer? Have you gone into the printer properties and set it to share? Right click on the printer in printers and faxes and select properties. Click on the sharing tab and clickn on the circle next to share this printer. (Windows xp)
Jan 12, 2009 | Lexmark Computers & Internet
1800HG ROuter + Home Network
Rather than try and explain how to set things up here (would be a rather long answer!)... follow the links below ;)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Go here for instructions on setting up printer sharing
http://www.home-network-help.com/share-printer.html
go here to setup file sharing
http://www.practicallynetworked.com/sharing/xp/filesharing.htm
Aug 30, 2008 | 2wire 1800HG Router (RG1800HG00)
Facebook Apps Logo
477 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
