Can I turn the OSD off on an rx v767? - Audio Players & Recorders
IPad connected to V-AUX of Yamaha RX-V767 - audio only on one side
Try switching the input cables between red and white, and see if the audio switches sides. Your cable may be bad.
Jan 29, 2013 | Yamaha Audio Players & Recorders
Yamaha rx-v767 factory reset
HI
Procedure for resetting the unit
To reset to the original factory settings
select this sub-menu and
press the "MAIN ZONE "(power) key to turn off the power. Any protection history also will be initialized at the same time.
hope this helps
Kind regards
M.Mathis
Jun 22, 2012 | Yamaha Audio Players & Recorders
I just purchased a yamaha RX-V767 receiver. I have a polk surround sound speaker system 5.1 that have an impededance of 8 ohms. The receiver has an impedece adjustment knob on it. would it be safe to...
No, you don't want to do that. The Ohm output on the amplifier must match the speakers. Run 8 Ohm speakers on 8 Ohm and run all your speakers on the same impedance (Ohms). Your gonna burn your amplifier up if you run different impedances.
Mar 24, 2011 | Yamaha NS-A60X Main / Stereo Speaker
HI A few days ago RECEIVED PURCHASED Yamaha RX-V767 Receiver Titanium NOW DOESN'T WORK. WHEN I TRY TURN ON NOTHING HAPPENS, I DON'T KNOW WHY BECAUSE YESTERDAY WAS OK, AT NIGHT I FINISHED LISTENING...
you are owned a no quibble replacment. You have faulty circuitry and no user can replace or repair the internals at this early stage as you will invalidate any warrenty.
Jan 16, 2011 | Yamaha Audio Players & Recorders
I can't get the OSD display to appear on my monitor.
it's in the manual footenotes. osd will not work with an hdmi connection to monitor. it will work with s-video or component. just switch input when osd is desired.
Jan 28, 2010 | Yamaha RX-V661 Receiver
Yamaha RX-V730 OSD problem
I assume you have a component connected source coming into the Yamaha to give it sync and you are component connected out to the monitor. If you have no input you won't have osd on component only without a signal to sync lock.
It is always possible that the 730 doesn't actually have component overlay for osd, just its a 2in 1 out switched affair. Hence the manual says you also need the composite/ Svid as well...They certainly don't use both at the same time. Newer units have full up + down video conversion but at this age it won't have.
Oct 31, 2009 | Yamaha RX-V730 Receiver
Monitor problem
I don't see any OSD in the RX-V490 owner's manual. This unit only passes video through from a video source, like a VCR.
May 16, 2009 | Yamaha RX-V490 Receiver
Yamaha RX-V530 no OSD
There is no OSD on this unit. The Monitor Outputs are there in case you run video inputs to the receiver, which you don't.
Apr 26, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
47 people viewed this question
 Grubhead
Grubhead
