Why is my Dragger Alcotest 6810 showing error message 622?
The equipment has stopped working and it is the error message.
My SHarp calculator shows a "P E" message and quits working. Can this be shut off so I can use the calculator?
From a Sharp Printing Calculator manual
When the paper jams, the printer stops and the error symbol
"P.E" appears. Turn off the calculator. Tear off the paper tape
and then pull the remaining part of the paper forward and
completely out of the printer
http://www.sharp.se/cps/rde/xbcr/documents/documents/om/30_cal/EL1611P_OM_GB.pdf
Feb 14, 2017 | Sharp Office Equipment & Supplies
I am receiving the message "Unfortunately the launcher has stopped working". How do I fix it?
Google is your friend in such cases :>)
  • Unfortunately, Launcher has stopped - Android Forums at ... forums.androidcentral.com/...unfortunately-launcher-has-stopped.html
    • 27 POSTS
    • FIRST POST: 2014-01-25
    2015-12-30 · On powering up my tablet I get a message "Unfortunately, Launcher has stopped" & I ... up says unfortunately launcher3 has stop. i ... the launcher stop working ...
  • "Unfortunately, Launcher has stopped" error after 4.0.4 ... android.stackexchange.com/questions/23842 Tap OK on the "Unfortunately Launcher has stopped" window. ... Android launcher not working. ... unfortunately settings has stopped when adding widgets to nova launcher.
  • Steps to fix the Error message 'Unfortunately, launcher ... androidtipguys.com/forum/steps-fix-error-message-unfortunately...
    • 9 POSTS
    • FIRST POST: 2013-02-20
    2013-09-18 · Steps to fix the Error message 'Unfortunately, launcher has ... Steps to fix the Error message 'Unfortunately, launcher has stopped ... settings stopped working ...
  • Android Device Emulator- Error Message: 'Unfortunately ... https://software.intel.com/en-us/forums/android-applications-on... I wonder if somebodyhad experienced an error message 'Unfortunately, Launcher Has Stopped ... message 'Unfortunately, Launcher Has Stopped ... has stopped working ...
  • What does it mean "Unfortunately, Launcher has stopped ... https://www.ifixit.com/Answers/View/263569/What+does+it+mean+... whenever I try to go to a website, I get the message, "Unfortunately launcher has stopped working." Any fix?
  • "unfortunately Lenovo Launcher has stopped working ... https://www.ifixit.com/Answers/View/218973/"unfortunately+Lenovo... My A3300 tablet was put on charging. it showed "lenovo launcher has stopped working" and then it turned off.now it does not turn on. please help!!
  • Homescreen Launcher problems - Android Forums at ... forums.androidcentral.com/.../312587-homescreen-launcher-problems.html
    • 17 POSTS
    • FIRST POST: 2013-09-07
    2014-02-25 · Homescreen Launcher problems Hello ... but working with Android for 2 years now ... "Unfortunately, Launcher has stopped" and I get chucked back to ...
  • Android 4.0 emulator always has a crashing Launcher ... stackoverflow.com/questions/9155417
    • 10 POSTS
    • FIRST POST: 2012-02-06
    2013-10-17 · Android 4.0 emulator always has a crashing Launcher? ... problem is "unfortunately, launcher has stopped". ... the size and tested again and things were working ...
  • How To Fix: 'Unfortunately The Android Process Media Has ... www.youtube.com/watch?v=arKBbSUt-_Q
    • BY THEFRESHGAMEPLAYS
    • 6 MIN
    • 550K VIEWS
    2012-12-08 · How To Fix: 'Unfortunately The Android Process Media ... Unfortunately (app name) has stopped ... Unfortunately google play store has stopped working ...
  • May 08, 2016 | ZTE Cell Phones
    Why my canon ir1133 printer is showing e733/0000 error message?
    ERROR E733-0000 Stops printing and shows sign "Turn ...
    www.fixya.com/support/t21602993-error_e733_0000
    Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
    Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
    Shows an error of E03
    Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
    Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
    Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
    Precor Error Code 03 E03 EEPROM Test Error
    Oct 03, 2015 | Exercise & Fitness
    V-fit treadmill won't start and shows error message.
    Test the power supply coming to the equipment and try again. If the problem with power is o.k proceed with LUBE very important. God bless you
    Apr 07, 2013 | Exercise & Fitness
    Error Message Service required
    not enough info require make and model to ensure correct answer
    Sep 22, 2017 | Office Equipment & Supplies
    Error code E000013-0001
    getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
    The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
    Answer :
    The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
    Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
    Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
    Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
    Dec 22, 2010 | Canon imageRUNNER C6800 Copier
    Reset e machine laptop 6810 to factery
    Hi Pilot,
    Thank you for contacting Fixya. This is Anil.
    I understand that you want to reset your Emachines 6810 computer back to factory settings.
    I will be glad to help you with it. Please follow the below mentioned steps to perform full factory restore:
    Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
    I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us with the below mentioned details:
    1. Do you receive any error messages? If so, please mentione it.
    2. Have you made any changes to the computer?
    We will be glad to help you.
    Thank you
    Regards,
    Anil.B.R
    Jul 17, 2010 | E-Machines M6810 Notebook
    I have a sunpak 622
    Sunpak does not offer dedicated (TTL) module to any digital cameras. The flash can only be used in auto mode, while the camera is set to full manual. The lens has to be stopped down according the working aperture on the flash, correct exposure will be maintained by the built-in sensor of the flash. Fire the flash using a simple hotshoe-to-PC cube if your camera doesn't sport a PC connector. Trigger voltage of the 622 is safe.
    Jan 31, 2009 | Sunpak 622 Super Pro TTL Flash
    k24674
    jasbo
    jasbo
