Question about Miller Welding Tools
Why does fuse keep blowing on green wire that goes to starter on Miller bobcat welder
    Top Expert:
  • Miller Master
  • 50,211 Answers
Means you have a dead short someplace in the starter circuit possibly the solenoid
Posted on Apr 07, 2015
2 Suggested Answers
  • 827 Answers
SOURCE: I have a miller bobcat 225, it keeps blowing 30 amp inline fuse on a blue wire that runs to the hot side of the starter, any idea?
millerwelds.com will let you down load a manual for this unit, it can help you with this problem, also you can call miller and tech support should help
Posted on Jan 23, 2015
Miller bobcat 225 wont crank replaced bayyery, starter and switch where should i go from here?
Check to see if the starter solenoid turns on a 12 volt test light when the ignition is held in the crank position.
Nov 02, 2016 | Miller Welding Tools
I have a 2007 miller bobcat it has spark cleaned carb new plugs new filter and it won't start
did you try a touch of starter fluid in the carb just to verify that the engine is getting spark? ethanol gas... if it hasn't run in a few months and you left the gas in it... you better revisit the carb cleaning
Dec 13, 2015 | Bobcat Miller 250 Welder Generator 907212...
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Jan 22, 2015 | Bobcat Miller 225 Welder Generator 907209...
Miller bobcat 225ntblows fuse when you put fuse in
Stop using the fuse as a tester. Find the short circuit with an ohmmeter.
Nov 09, 2014 | Miller Bobcat 225NT 8000 Watt Generator...
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Won't strike an arc,fuses ok brushes and slip rings ok
check the wiring and terminals on the earth return wire. They can break away inside the clamp ends. check the wiring and the hand piece
Oct 07, 2013 | Bobcat Miller 250 Welder Generator 907212...
Would like to know how much a used bobcat migwieldier costs?
Depending in the city you are in. Here in N California the average price for the Miller Bobcat 225 is 3,425.00. Try your local Praxair Distribution welding store.
If this was useful please vote.
Feb 23, 2011 | Bobcat Miller 225 Welder Generator 907209...
Need to know how to hook up to 220 power supply what wires go where we got a red wire,black,white, and green which is ground can u help?
L1
L2
L3
Neutral
Earth
North America
Black
Red
Blue
White
Green
There is no blue cable in a 220V, so you have only; white, black, red and ground always green colored wire.
Looking your plug frontal side.
Green Ground on top (semi-circle)
black on left
red on right
white on bottom (neutral).
Jan 10, 2011 | Miller Bobcat 3 Phase Welder Generator...
Welding Tools Logo
189 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
