Question about Craftsman Garden
Craftsman riding mower 18.5 HP Briggs and Stratton engine runs about 10 to 15 minutes then stops replaced coil and battery what else can be wrong
    Top Expert:
  • Craftsman Master
  • 10,875 Answers
Check all safety switches,seat,deck,clutch,etc,pull single wire off from coil,run the motor,if it doesnt stop then the safety switches are bad,i disconnected my wire from my coil and put a wire on with a switch and ground the switch,to shut it off,but,beware your safety devices are gone,be careful.send me your old coil,i could use it.
Posted on Apr 07, 2015
    Sergeant:
  • Craftsman Expert
  • 187 Answers
Tracking down fuel problems.
  1. Make sure there is plenty of fresh fuel in tank. High Octane less than one month old. Water in the fuel system will often cause hard starting, low power, backfiring, surging or stalling
  2. Is there a cut off valve at the gas tank? If so check that it is open or working if it is electric.
  3. This step comes from repeated personal experience with JD gas tanks. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. (look at the filter before removing it, it should look at least 1/2 full of fuel.) If gas does not pour out remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. The vent is that tinnnny little hole in the center of the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out any blockage inside the gas tank.
    Do your self a favor, leave the gas cap off and turn the outlet air on your compressor down below 20 psi. If the tank is nearly full you will blow gas out of the tank. Do this outside if possible; at the very least you need a well ventilated area. After blowing air from the air filter back to the tank, you may have to reverse the process and pressurize the tank to get the fuel started. I place my hand over the open tank and hold the air hose between the joint of my thumb and forefinger to seal the tank, and then squeeze the trigger. Once you have a good fuel flow out the line to the filter, put on a FRESH FILTER. Try cranking the engine. If it still does not start move on to the fuel pump and carburetor
  4. Check the fuel pump. The fuel pump system on the twin Koehler and the Twin Briggs (and others) are almost identical. Watch this excellent, eight minute, video to learn how to check the fuel system, including the pump, up to the carburetor. .
  5. Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
  6. Note: My engine was starting hard and dying in the field this year (March 2015). While doing a valve adjustment, I found a hairline crack in the bend of the vacuum hose powering the fuel pump. It's the short hose running from the valve cover to the fuel pump. The fuel pump will not work if this hose is cracked.
  7. Many systems have a fuel shut off solenoid. This is a small cylinder on the bottom of the carburetor. It has two wires running to it. It should make an audible click when you turn the key on. If it does not click you will have to replace it or track down an electrical problem.
  8. If this has not solved the problem you may have to remove and disassemble, clean, or rebuild the carburetor at this point. You may have water, dried fuel (varnish) or trash in the carburetor bowl. Before removing and disassembling the carburetor try draining the bowl. Or, take the bowl off, careful not to drop the small parts inside. Clean the bowl and replace. I often remove the bowl on small engines and save the hassle of a complete carb removal.
NOTE: Connect a volt meter across the two battery posts. If battery voltage drops below 9 volts when cranking or while the engine is running, the fuel cut off solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good, and the voltage is still dropping, you may have a bad starter motor which is drawing too much amperage.
If you find this fuel checkup does not solve the problem, repost your question with updated info and I will walk you through the next step. Tracking down a spark problem; yes, your problem could involve the coil. (Not as likely as fuel)
    Top Expert:
  • Craftsman Master
  • 47,724 Answers
Fuel pump of course or dirty fuel filter dirty carb
  • 246 Answers
SOURCE: 1998 craftsman mower w/19.5 hp Briggs and Stratton will not fire.
Hello B-N-L:
>>I Suggest you Check the Ign Module First and then the Safety Switches if the Ign Module (Coil) is Good. Remember that the Ign Module May Check Good, but if the Safety Switches Check Good, then Most likely the Coil is in the Early Stages of Breaking Down and will Cause this Problem.
>>You can Check the Ign Module (Coil) by Using the Following Instruction File.
The Following is an Instruction File I Made for Checking and Repairing this Problem.
>>Run the Engine Until it Quits, then Remove the Spark Plug. Wrap a Wire Around the Threads and Attach the Other End of the Wire to the Engine Block Turn the Engine and See if the Plug Fires.
>>If No, then Disconnect the Shut Off Wire at the Control Bracket First, Check for Fire at the Plug. If Still No Fire at the Plug; Then Disconnect the Shut Off Wire at the Coil (usually requires removal of the blower housing) and Check for Fire at the Plug.
>>If No Fire at the Plug , then the Coil/Ign Module is Bad. The Coil/Ign Module to Flywheel Gap is .020in.
>>On Some Model JD Engines, there is a Igniter that Goes Bad and Not the Coil. The Igniter is the Same as an Ignition Module. If the Plug Fires at Anytime During these 2 Checks, then a Safety Switch or Wire May be the Problem. Yes the Engine will Turn Even with a Bad Seat Safety Safety Switch. Usually if the Engine will Not Turn with the Ign Switch; the Blade Safety or Neutral/Clutch Safety Switch is Usually the Cause of this.
>>The Starter Turns and the Engine Doesn't Fire is an Indication of a Bad Coil/Ign Module or a Faulty Blade Safety Switch.
>>The Blade and Clutch Safety Switches Prevent the Starter from Engaging so the Blades or the Mower Does Not Move when the Starter Turns the Engine.
>>The Seat Safety is Designed to Stop the Engine if the Blades are Engaged or the Clutch Safety is Not Engaged when you Leave the Seat.
>>The Following is an Instruction File for the Safety Switch System. Any Input is Appreciated.
>>The Color Code of the Wires May be Different than those I Use as a Reference in the Instruction File.
>>**PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed.
>>**Now. On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch (Clutch/Brake) Jumper from Same Color Wire (Example: White to White) First and then Check for Fire, Now Include the Black to Black Wires if No Fire.
>>Check the Clutch/Brake and the Blade/PTO Safety Switches First.
>>Check the Seat Safety Last. Usually the Seat Safety is Not in the System for Starting the Engine. Just to Ensure Someone is in the Seat when Engaging the Transaxle and/or Blades. Use a Paper Clip or a Short Wire to Make a Jumper.**
>>Use a Volt/OHM/Continuity Meter and Check the Continuity of the Switch. The Meter should Show when the Contacts are Closed and Open. The Meter will Swing All the Way Over when the Switch Contacts are Closed and Swing Back to the Rest Point when the Switch Contacts are Open.
>>If the Safety Switches Check Good, then Check the Ign Module (Coil).
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 413 Answers
SOURCE: engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
Posted on May 29, 2009
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
  • 52 Answers
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
Posted on May 02, 2010
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
What is the air gap between the flywheel and coil on 22 hp
.030 (thirty thousands). I use brass shim material as it is not magnetic.
Jul 19, 2014 | Briggs & Stratton Briggs Stratton Intek V...
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
Battery want charge... ok i paid to talk w/ a
Sounds like the voltage regulator is bad--will run the battery down!
Feb 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Lawn mower / could not find a product on lawn mower, but a car mechanic can tell me.
http://www.google.com/search?q=18+HP+briggs+and+stratton+SERIAL+NUMBER+LOCATION&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a TRY THIS.RICHARDM69
May 20, 2008 | 2001 Ford Excursion
Garden Logo
118 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
