Question about LG Flatron L1750S 17" LCD Monitor
Samtron monitor color display 56V
My monitor is having this colour problem. I have opened the case and cleaned the circuit board of dust. I am advised to give a gentle tap of the monitor by my computer friend, surprisingly for a few hours the monitor was working perfectly, now, again it is not displaying the red colour, I tried another slap for no use.Can any other try could be done by me. pl assist
  • gunu Nov 16, 2007
    hi i am new to this forum and i do have the same problem with my monitor and plz post some technical help as if how to solder the connection with the picture tube [CRT] ... i tried the solution posted but all in vain and plz also give steps how to do that or any links where in i can learn how to solder that part of CRT tube
  • rugrat Nov 28, 2007
    My screen turns red when I have run my computer for a long length of time.
There are 15 Pins in Monitor cable which is connected to VGA port on the rear side of the Tower. First, we need to reset BIOS settings, and then try again - onboard video card only. for Add-on Video card try reseating video card in diff. slot if possible / reseat video card and try again. if it does not fix it, it could be the problem with Monitor RGB Connection - near the electron gun in the monitor CRT tube. resolder RGB , it will fix it.
by
Kasi M
Posted on Nov 15, 2007
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
Samtron Monitor 56V Display Problem
your power supply is probably bad. open the case with it unpugged and look for leaking or crowned capacitors. most electronic repair shops can replace them for you
Jan 10, 2010 | Computers & Internet
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor problem
i think the problem is in your monitor and it is not manuall. any part of your monitor might have been damaged ,so get it checked by an hardware expert
Feb 24, 2008 | SAMTRON 55V 15" CRT Monitor
Screen menu displays locked & unlocked
possible faulty VGA Controller board.
Dec 03, 2007 | Gateway FPD2275W LCD Monitor
Display color has been changed to rainbow.
AS hit the monitor on its top the color changes to normal. so what can i do AS IT COMES TO normal position after hitting that cleary indicates that there is no parts failure. 1 there is a loose contact in or near crt base. 2 loose contact in connector. 3 computer to monitor cable loose.
Sep 15, 2007 | SAMTRON 55V 15" CRT Monitor
Need solution for the yellow display of my monitor
You can see one ic in right of crt base,plz resolder it (90%sure)
Sep 14, 2007 | SAMTRON 55V 15" CRT Monitor
I have the SAMTRON 56 V 14" COLOUR MONITOR .
change the eprom (A41dDC) after connect pc then switch on monitor
sushil91077rajbanshi@rediffmail.com
Sep 04, 2007 | SAMTRON 78DF 17" CRT Monitor
Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
LG Flatron L1750S 17" LCD Monitor Logo
187 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
