Hello, I just moved in new flat and I have this machine, but I don't know how dryer work, how can I turn on it? thanks
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
Turn the button and push it
Posted on Apr 07, 2015
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Dryer not drying clothes
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
Aug 20, 2011 | Dryers
ASKO 7000 series washer drum stopped rotating. Smelled of burning. Could not turn the drum by hand. Guessing a burned out bearing as electronics and pump still work and are trying to turn steel drum. ...
check inside your washer for nails or other objects . I already seen a nail fall down in one of the basket holes and the nail stuck into the outer tub not allowing the basket to spin. If you dont see anything in the basket holes, then it is your bearings. The burning smell is coming from your belt. The motor is spinning but your basket is not. It is cheaper to buy a new washer. In ordered to fix your washer you have to rebuild it. The bearing are built into the outer tub of the washer.
Jul 13, 2011 | Asko 8005 Front Load Washing Machine
We installed a stacked set of WFW9250WW and WGD9270XW Whirlpool washer and dryer. When we turned on the washer, everything worked fine until the spin cycle. The machine started vibrating violently and...
Hello, welcome to FixYa.
I understand you have a problem with your stacked washer & dryer, thank you for providing the model number (of both) that is a good start... however I need to follow that up with a couple of questions.
Are these "new to you" machines or have you had them prior to this and just never stacked ?
Also had you run the washer before they where stacked and not noticed an vibrations violently/noise like a hammer spinning inside?
Finally, what method did you use to fasten the dryer to the top of the washer and did you remove the cabinet top of the washer before stacking...for the record it should not be removed as was the case with some other manufactured machines.
Let me know if you can add anything further along with the make & model. I will wait for your reply to move forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 13, 2011 | Whirlpool Washing Machines
Hello, I just purchased a used brother 170D and the thread keeps wading up underneath. Can you please let me know what the problem is Thanks, Glenda
It is more than likely your top threading, insert a new needle (flat side facing away) because it could have a burr or a slight bend in it. Now totally rethread your machine, with the presser foot up, then pull on the top thread, it should move smoothly, put the presser foot down, pull the thread, it should barely move. This procedure should seat the thread in the tension discs. If, this does not solve your problem, return the machine and get a new one. Good luck.
Mar 18, 2011 | Brother Sewing Machines
Baumatic WD55 Washer Dryer - How Do i work it??!
machine needs to be on half load for dryer to operate
Dec 26, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Electrical
hi thanks for the question. it would help if i had the model # you i can look it up. but i think you have 2 cords one from the dryer and one for the washer if you only have one let mi know if 2 cords both cords must be hooked up to power source thanks the appliance doctor
Aug 23, 2008 | Kenmore 98702 Stacked Washer/Dryer
The dryer works, makes noise
YOU HAVE ONE OF TWO THINGS GOING ON EITHER THE IS DEBRIS STUCK IN THE BLOWER AND/OR IN THE DRUM FELT OR YOU HAVE A DRUM ROLLER HAS FAILED AND HAS A FLAT SPOT ON IT USING YOUR MODEL NO# GO TO WWW.SERVICEMATTERS.COM AND PULL UP THE JOB AID MANUAL TO ET INTO THE MACHINE
May 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
