Question about GE WBVH6240F Front Load Washer
The lock mechanism for the panel/buttons is stuck - I can't push any buttons due to the lock.
    Top Expert:
  • GE Master
  • 43,014 Answers
My 2002 vw cabrio door locks stuck in locked position even though the lock button by window goes up and down when you push lock and unlock button on door. The door is locked when you pull handle but the...
If you would like to fix this yourself, you will be needing to pull the door panel off that side and finding the problem inside the door, but, before you do, here's what you are looking for:
The door latch is fastened to the door jamb with screws.
There are several wire-like levers that come to the door latch and tell it whether to lock or not, to open or not, etc.
The wire type levers come from the two handles, ( inside and out,) and the locking mechanisms, inside and out.
One of your has broken or come apart.
Maybe a bushing has failed at the end of one of the levers.
Be blessed.
Jan 23, 2013 | 2000 Volkswagen Cabrio
The PC on/off button (push in button) is stuck & the PC lights go into blink mode.
Most newer PC Towers have a front panel that can be removed exposing the push button mechanism. Check to see if yours does. If so remove the the front panel/bezel. You will see the mechanism that actually pushes the on and off button post. Check the spring mechanism to see if it may be broke or just out of alignment. If you are unable to remove the front cover/bezel then the switching mechanism is inside the tower and should be taken to a repir shop for repair or replacement.
Dec 12, 2010 | Computers & Internet
Central locking (not remote) failing on passenger door. Can't lock it at all. The button moves, but you can still open it. Thanks
remove door panel and inspect for dirt and cloged up manuel push button. also check and see (with panel off ) if the lock mechanism is moving the rods inside the door!
Nov 23, 2009 | 1994 Mazda 323
My front passenger door does not open neither from the inside or the outside. it looks like the lock is stuck in the locking position and won't open from the drivers side push button or the passenger's...
hi deleon,
on your door, if you remove the panel from the inside, you should see a lever connected to the handle that is supposed to disengaged the door hinge opening the door.
your may have this part broken due to corrosion, or there is a possibility that the lock did not disengage leaving the lever connect to the door handle not disengaging the door hinge.
have this checked with a local mechanic or consult the service manual for DIY.
if you have other questions, just lemme know.
regards,
voodoo
Jun 06, 2009 | 2001 Ford Explorer Sport Trac
Pause button is stuck
hi soblessed,
the plastic push lock that holds the button is possibly broken, but hopefully the mechanism incorporated with the button has not been damaged because it was pushed too far.
to have this issue resolved, you may use something pointed to nudge the button from its place and free it from being stuck. Or you may remove the screws from the button, freeing the upper case from the lower case exposing the other side of the controls, so you can push the pause button out.
regards,
voodoo
Apr 19, 2009 | Emerson PD6870RD Radio/Cassette/CD Boombox
Camera error
Your lens is not communicating properly .
It is stuck it is due to mechanically problem you are having this error.
Jan 24, 2009 | HP Photosmart 935 Digital Camera
Locking mechanism on 95 Jeep Cherokee Sport stuck in ''up'' positio
Push outside handle, simulating opening the door. At the same time, use a screw driver and pry open the jaws.
Nov 19, 2008 | 1998 Jeep Cherokee
Driver side door lock stuck
have you tried to pull on the handle on the inside of the door or push the button on the outside while trying to move the latch with a screwdirver
Jul 28, 2008 | 1998 Jeep Cherokee
Power locking hubs
better make sure that voltage is not really present at the terminals, the voltage at the terminals is present only for a about 3 to 4 secs which is needed to activate a small dc motor inside the hub. The dc motor when activated turns the locking mechanism accordingly. swithcing of the power button applies a reversed polarity to the dc motor which will revolve the other way around thereby effectively disengaging, this time the lock mechanism the hub. The common problem of the power locking hub is the worn out carbon brushes which connects the small dc to the power source.
Jul 22, 2008 | 1992 Toyota Land Cruiser
Stuck Microwave door
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts. They can only be accessed and examined if the cover is removed from the microwave. In many over the range models, you can access the door parts by removing the control panel assembly. Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
Jul 30, 2006 | Whirlpool MT4070SK 700 Watts Microwave...
GE WBVH6240F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
