Question about Indesit Washing Machines
I would like to know how to repair my samsung washing machine, i plugged to 220V ,but not properly running,this bring from bahrain,any volage problem
    Top Expert:
  • Indesit Master
  • 47,720 Answers
With no problem posted we can not help you
Posted on Apr 07, 2015
My SAMSUNG washing machine model WA10F4 won't open water inlet. Please advice on what to do..need it badly. Kindly suggest where to bring for repair.
seems like the water inlet solenoid isn't working you may contact samsung directly to have a repair man fix the issue since samsung has all the parts for their washers
Feb 26, 2017 | Samsung Washing Machines
My 110V washing machine was plugged into a 220V outlet. After briefly emitting a burning electrical smell, the washer now does not work. Who can fix it?
you first have to get a technician out to properly diagnose the extent of the electrical damage
get a quote to fix as the fix may cost more than the unit to replace
other than that junk it and get a machine that runs on the proper voltage
Sep 16, 2016 | Kenmore Washing Machines
I have a Miele Washing Machine and the power light is out and the machine does not run. Why?
Because some part of the internal componentry of the machine has developed a fault and needs diagnosis by a qualified technician. You can check this by testing for volage at the machines power button, make sure you know what you are doing
with regard to electricityif you intend to attempt this!!!!!!!!!!!!
Jul 06, 2015 | Miele Washing Machines
How to convert 50 hz waterpump to 60 hz??
you cant but difference between 50/60 hertz should not stop in running does the rest of machine work ok does it wash spin if so I would be lokking for wires of jammed pump ect
Mar 08, 2014 | Samsung Washing Machines
Sir, I would like to ask if this samsung washing machine model Diamond Drum WA80V3 220V - 50Hz - 330W can be use in Cebu City, Philippines where the electricity power cycle running is 60Hz?
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
Jun 17, 2011 | Samsung Washing Machines
I plugged my kenmore washing machine into 220v
Presumably 115v?
Need repair man, sorry ;-0(
Good luck, John C
Jun 12, 2011 | Kenmore 24032\24036 Top Load Washer
Dewalt
Hi there!
I am afraid you can't do that by the changing plug. However, you can do that by using a Step-down Transformer which will bring 220V to 110v that is what your machine is designed to run on. Check the wattage of your drill before getting a Xformer. Usually the stepdown x-former should have a proper socket at the output side. Good luck.
Gamba
Jan 29, 2009 | Dewalt 18 Volt Compact Drill Kit
WA71N2 plugged to 220V should be 110V
The Fuse for these model is 110V - 250V, so definitely the machine will still light up for a moment then black out. So if you accidentally plugged it to 220V (if it is 110V) you have to change the whole PCB. Electric current are distributed by PCB which only handles 110V.
I suggest when you change the PCB try to change also the Fuse to 110V only so that next time if by accident it was plugged to 220V you just have to change the Fuse not the PCB.
I
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung WA71N2, plugged to 220V should be 110V only
chang the board! servise center will charge probably 400sr
Washing Machines Logo
35 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
