Question about Cameras
When I put my 4gb SD card in it just says no card after saying waiting
    Top Expert:
  • Cameras Master
  • 10,875 Answers
Wiggle the card and push in and out a few times,contacts get dirty
Posted on Apr 07, 2015
    Top Expert:
  • Cameras Master
  • 52,086 Answers
Possibly wrong type of card .
  • 3 Answers
SOURCE: Coolpix 5200 + 4GB SD card
Any size SD card will work. The capacity limit is with the card, not the camera. All the camera does is serve as a recorder/reader for the card.
Posted on May 13, 2008
t00nz
  • 4738 Answers
SOURCE: Can't unlock 4gb sd memory card
There's a tiny slide switch on the side of the card. Slide it to the other position and try again.
But one thing I've noticed is that you mention that the card is 4GB. As such, it's likely that this card is an SDHC card. There is also a possibility that your A540 camera is not recognizing the card as the SDHC format came out well after the A540 was designed.
If you're still having problems with your 4GB card, recommend trying again with a standard SD card (2GB or less). 2GB standard SD cards are very inexpensive, and can be found on Amazon for about $7 with free shipping.
And hang onto the 4GB card. It will come in handy again someday.
Posted on May 27, 2009
  • 161 Answers
SOURCE: hi,just bought a 4gb sd card for my digimax s600
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Posted on Sep 09, 2009
Testimonial: "hi,thanks for the quick response,i don,t know if it has what you said.it just says on the bottom of the camera..digimax s600 cyber/630."
  • 11967 Answers
SOURCE: New 4gb sd card will not work. card error
Is the slide switch in the unlocked position? Are you formatting it in the camera? Are the card contacts dirty?
Posted on Dec 07, 2009
Obertelli
  • 3006 Answers
SOURCE: I bought a 4GB Memory Card for my Samsung Digimax
Your problem is that your camera only takes standard SD cards up to a maximum of 2GB. The card you have bought is likely to be a 4GB SDHC model. SDHC is a later development of SD; SDHC compliant devices can still use older SD cards, but SD-only devices cannot use SDHC. This is a hardware limitation so there is no way at all to use an SDHC card in your camera.
Note that if your 4GB card is definitely an SD and not an SDHC then it's still incompatible with your camera: very few standard SD devices were ever made with the firmware and hardware to handle the different memory addressing architecture used by the larger capacity card. Some cameras did have firmware updates to allow the larger SD card to be used, but yours is not one of them.
Your only fix is to sell your card (or keep it for another device) and to buy a regular SD card no larger than 2GB maximum capacity.
I trust that my reply has answered your question fully, please take a moment to rate my answer.
Posted on Mar 23, 2010
What's your problem?i put a 4gb memory card in my canon SD 200 and it says error why
The SD200 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Mar 05, 2012 | Canon PowerShot SD200 / IXUS 30 Digital...
How to format sd card for rollei prego da5? I put a new 4GB sd card in my rollei, camera says: "Your card has to be formatted. Click ok." When I click ok, it says: "Card cannot be...
The DA5 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You have to use SD cards, 2GB and smaller.
Sep 29, 2011 | Rollei Prego DA5 Digital Camera
Put in a 4gb SD card, camera says needs to format, I say ok, it say all pics will be lost, I say ok, and pick continue and then again it says needs to be formatted, and repeats this again and again
There are no 4GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 06, 2010 | Kodak EasyShare Z740 Digital Camera
Bought a 4GB SD card for my easyshare z700 camera. when I try to format it says to select "continue". when I select it loops right back to "memory card requires formatting, select continue". All the while...
The Z700 works with SD cards. Your 4GB card is actually an SDHC card (the HC stands for High Capacity) and will not work in the Z700. You'll have to stay with SD cards 2GB and smaller.
Jul 13, 2010 | Kodak EasyShare Z700 Digital Camera
Sd card
Sorry, but your camera was designed before the 4GB SDHC card came out. Although they look exactly the same as a standard SD card, they are not. Your camera can only use standard SD cards (2GB or less).
May 12, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
We put a new 4gb flash card in and on the display it says no memory card,we then put the old memory card in and that says memory full but says theres no photos on the memory??pls help
Your camera probbaly does not use SDHC... just SD...
Find an SD memory card, it will work. The 4GB card says "SDHC", not "SD".
Please post the brand and model or whatever you can ... which camera?
Sep 19, 2009 | Cameras
May 27, 2009 | Canon Cameras
Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Feb 23, 2009 | Dell Inspiron E1505 Notebook
My computer nor samsung alias wont read my 4gb pny microsd chard
I doubt that your phone accepts the 4GB version of the micro sd card, try the 2GB
Feb 22, 2009 | PNY 4GB microSD High Capacity Mobile Media...
SD cards
Do the 4GB Cards say SDHC on them? They should. SDHC is simply "Secure Digital High Capacity". They're high capacity SD cards that hold more than regular cards. In this case, 4GB. The problem with these is that they need to be supported by the device. I've never put an SDHC card into a device that doesn't support them, but it looks like that's what your situation is. The highest memory capacity a non-SDHC compliant device is capable of 2GB. I recommend that you return the 4GB cards and buy 2GB cards instead.
Jun 16, 2008 | Samsung NV3 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
