Question about Kitchen Ranges
After my oven is lit why does it continue to make the clicking noise that it makes to light . I had the ignitor replaced 2 months ago
    Champion:
  • Kitchen Ranges Expert
  • 220 Answers
Possible reasons ignitor may be bad hair line crack, not properly grounded, bad or pinched ignition wire, or bad spark module
Posted on Apr 07, 2015
    Top Expert:
  • Kitchen Ranges Master
  • 51,107 Answers
Has to be s sensor problem google make and model /manual
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: idiot cousin sat stove outside
Sitting out in the weather would not hurt the ignitors but if that cousin of yours failed to tape over the regulator then air and humidity ruins the pressure regulator. Try tapping on the regulator to loosen it up.
Posted on Apr 08, 2011
I have an electrolux EOG6330 gas oven and when I light the grill the igniter continues to spark,the only wayto stop it,is to turn the grill off.Any body know what causes it and how to sort it?
Hello dishboy,
There are 2 possibilites causing that
1) The electrode(spark plug) for the grill is is built up with a bunch of grime and not telling the spark module the burner is lit and turn off the spark. The electrode could be cleaned with the green srubby side if a kitchen sponge,or relpaced.
2) The electrode is telling the spark module to turn off but the spark module isn't responding, to turn off the spark. The spark module would need to be replaced
I hope this helps,
Gene
Aug 04, 2011 | Electrolux EOG6330 Gas Single Oven
Idiot cousin sat stove outside about 2 months now oven nor broiler will light ignitor makes no 'clicking' noise should i replace both ignitors or is there something else i can check first...?
Apr 08, 2011 | Hotpoint RGB790SEHSA Gas Kitchen Range
Amana Gas oven does not work.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jul 15, 2010 | Amana RanARG7302 Gas Kitchen Range
Oven out/flat top has hot spot/burners ticking everywhere
heatman101
Jan 11, 2009 | Viking VGRC605-6 Gas Kitchen Range
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Oven will not light
heatman101
iuop
Nov 19, 2008 | Whirlpool SB160PEE Gas Single Oven
Hotpoint Gas oven doesn't light
Sounds like the oven ignitor is weak.  If everything else is working it must be a bad ignitor.  These are usually easy to replace and can expect to pay $70-$100 for the part.  Check to see if it glows when in bake mode first.  If it does then replace the ignitor.  You can look at the ignitor,  when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced.  Let me know if you have further questions.
Oct 12, 2007 | Hotpoint RGB790SEHSA Gas Kitchen Range
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
