Question about Cell Phones
Dropoped it on the floor, nw oly whitw stripe on the lef, not operating. Probably discnnected wire, how to open my phone?
    Top Expert:
  • Cell Phones Master
  • 6,702 Answers
You could have a look on fixit.com, to see if they already did your phone. The opening that is. Most if the time you won't be able to close it, because most modern smartphones are glued and you need these glue stripes as spare parts because you can't use them twice.
Posted on Apr 07, 2015
2000 ford explorer reverse light wire color, and location in the front of car.
The reverse wire is black with a pink or purple stripe usually on Ford and is located under the hood below the brake master cylinder and brake booster in the wire harness that runs along the frame to the rear.
Im not exactly sure which cable that wire is in, but it will be the one that runs along the frame to the rear or the one that runs along the floor in the channel along the floor at the base of the door up to the kick panel where it joins the wiring harness in the dash.
Be careful with the wiring in this car. Ford uses a lighting controller to operate everything in the interior and exterior lights and you don't want to damage it. Used they are in the hundreds last time I had to buy one.
That 16 or 18 gauge black wire with the purple or pink stripe carries +12 in reference to chassis to the backup bulbs in the rear and is probably fused at 10 amps.
Make sure you test it with a test light before you cut or hack anything.
DO NOT TOUCH ANY WIRES THAT ARE BRIGHT YELLOW OR ORANGE. They are for the air bags and they will go BOOM and you will be stunned and you will know pain.
Hope that helps.
May 09, 2015 | 2000 Ford Explorer
Hi,my phone wires have came out of the conection box on the wall,please could you tell me weare they go ,i have white wire with blue stripes going to A,blue wire with white stripes going to B, nothing...
In "phone technician talk" the BLUE pair is #1 (pair), the ORANGE pair is #2 and GREEN is #3. This is standard telephone wire in the USA. If you live in the USA and you have one telephone line in your home, the Blue pair (One wire will be blue with a white stripe and the other will be white with a blue stripe) is where the dial tone should be. (This is practice, NOT LAW) Again, if you are in the USA, this wire should terminate in a RJ-11 (common name) box fastened to the wall. Your telephone device should have a modular plug connection (also commonly called a RJ-11) which should fit into the telephone "Jack".
What should you do? If your situation is described above, plug the phone into the jack. If the RJ-11 is damaged, purchase a new wire and install it into the telephone. Strip about 1/4 inch of insulation from the first pair. Put the hand set to your ear, touch the wire to the blue pair on the back of the jack (inside might be a good word here) If you hear dial tone, yo have made the connection. Loosen the screws and attach the wires. If yours does not have screws but rather little slices of metal to attach the wire to, you can purchase the special tool for this at the BIG box store for a buck or two. OR ... you might make the connection with a pair of needle nose pliers. Be aware, if the phone rings while you are doing this, the ringer operates at 60 volts and you will get a tingle. How to avoid that? Do you have a second telephone in the house? Take it off the hook which will make the line busy so it cannot ring.
If you are not in the USA, similar principles apply, touch the wires together until you get a dial tone, make the connection using what ever device is approved in your country. Once you find the dial tone, take the second phone off the hook so you will not get shocked if the phone rings.
I hope this response is what you expected ... thanks for your inquiry @ FixYa.com
Jun 13, 2011 | Cell Phones
I have 2 whitw stripes about 2inch wide on my
It is probably just a stuck pixel. As long as the stripes are white it can probably be fixed easily. Read the article below and see if it resolves your problem
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Dec 29, 2009 | HP Pavilion dv9000z Notebook
Had broken read brake line. Replaced line and went
beg borrow or steal a pressure bleeder, start with right rear, lest rear, right front then lef front,
Nov 16, 2009 | 2000 Dodge Ram 1500 Truck
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Valiant 1963, was running ok but after I took out three spacers of the sparks did not run any more, Now I forgot the position of these 3 spacers.
it's not the spark plug spacers for you probably did not connect the spark plug wires in the proper order when you disconnected it. the engine doesnt run or backfires when you start the engine. next time, mark the wires and location before discnnecting. good luck
Jul 11, 2009 | 1995 Plymouth Acclaim
Need Repair for OL-3000
All programing functions are controlled on the main (stationary) board. All display functions are controlled on the Rotor (spinning board.) Here are some steps to take if you are having display problems. Remove the three mounting screws that hold the rotor to the motor shaft. The LED display board is attached perpendicular to the rotor board and is soldered to the rotor board. Over time, the connections break due to the centrifugal force of the spinning rotor. CAREFULLY, with a low amp solder iron and a fine tip, re-heat the board to the display. That should solve the problem. If you were a bit sloppy with the solder, remove the solder with a fine wick and try again!
Sep 16, 2008 | Wave Industries OLY-OL3000 Globe Phone
Contact Service in nokia 6300
its ur mobile software problem..after few days it ll show oly tat msg...operation of ur mob ll struk in future...so better reinstall ur mob software and then use it....same pro had for me also..i cleared by tis way oly
Aug 04, 2008 | Nokia 6300 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
