Question about Hotpoint Ultima WT960P Washer Front Loading, 7 kg., "A" Energy Rating
CODE F-05 NOT EMPTYING
NOT EMPTYING AND FLASHING F-05
  • 822 Answers
Check the pump for a blockage....
cheers
Posted on Apr 07, 2015
Indesit omega 1100
Just press the drum inside the m/c then check
Oct 15, 2013 | Washing Machines
Hotpoint hvf44 flashing f05 and not finishing cycle or emptying of water fully
f-05 relates to blocked pump.
remove the front kick strip and on RHS u will notice the filter.
if u can tilt the machine backwards and place a basin under the filter. also have a towel ready.
remove the filter and clean out. also make sure the pump head is turning freely
Jul 06, 2011 | Hotpoint Washing Machines
Machine flashing f 05 taken back cover off and cleaned hose,still not emptying of water, shall we give up or try something else? hotpoint ultima wf 860
make sure you have checked the pump itself, possibly a hairgrip/nail etc. jamming it. also make sure nothing blocking the actual waste hose itself.
Jun 19, 2011 | Hotpoint Ultima WF860 Front Load Washer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Error 05 colour ink light flashing
Use only original cartridge to solve this error code.
May 25, 2010 | Office Equipment & Supplies
My washer hotpoint wt741 is flashing up f05 and wont rinse water out
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Try this out:
Small panel at rear of machine reveals the pump,
Pull of the two pipes (Plastic clips hard to get off, Slide them sideways),
Remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left,
Pump can then easily be cleaned.
Mar 06, 2010 | Hotpoint Washing Machines
Hotpint washer will not spin
F 05 IS A PUMPING PROBLEM CHECK IF FILTER IS AT BOTTOM FRONT R H S.CLEAN OUT AFTER EMPTYING.IF NOT AT FRONT IT IS LOCATED AT BACK OF MACHINE IN PANEL AT BOTTOM . THE FILTER IS IN THE BLACK HOSE COMING FROM TUB. ++++ REMOVE PLUG BEFORE DOING ANY OF ABOVE +++++
Mar 23, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Ariston Washing machine A1636 - Flashing lights
what 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
Jun 20, 2007 | Ariston Technologies AW149NA Washer
F-00 flashing control panel w/ time
pannick!........ suggest you check the filter, the fault code suggests that for some reason it cannot empty. Regards Engineer
May 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Ultima WT960P Washer Front Loading, 7 kg., "A" Energy Rating Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
