Question about Grilling
Grill plate on my Thermos Outdoor Electric BBQ must be angled, tilted,or moved to maintain contact to heat and maintain contact, How do I tighten the connections on the electrodes? Springs won't work.
SOURCE: thermos grill-to-go.
found thermos website which I was unable to do previously. Thank you.
Posted on Jan 31, 2009
SOURCE: BBQ will not heat up to cook meat
you had the burners on before you opened the valve on the propane tank.
this causes the safety in the pressure regulator to cut off most of flow, and the highest temp you'll get will be about 200 degrees.
turn off the burners and the tank, then disconnect the tank and let site for a few minutes. reconnect everything, and make sure you open the tank valve before the burner valves.
Posted on Feb 01, 2009
  • 14 Answers
SOURCE: My Jenn air BBQ grill will not heat up all of
Couple things could be happening here. If you do exchanges, have you used more than one different propane tank since you've had this issue? This eliminates the possibility of a low tank pressure and a faulty tank connection. Next you need to look over the burners and the propane flow tubing. Spiders LOVE the sweet smell of propane and make their webbing inside the piping that get's the propane up to the burners. At your flow valves/On/Off knobs you'll notice that the propane shoots from the valves into a pipe with an air gap to gain oxygen. Look in there to see if there's any webs. Also should be a gap were that piping meets the burners, so you need to look there too. Depending on the age of the grill, you need to look the burners over. Corrosion & rust can cause the flame/propane holes in the burners themselves to cake up and close up causing much less flaming/heating opportunity. Also depending how much you've used it, it could be grease/dripping/sauce caked up over them too so they may need to be detailed/cleaned. It's not a pretty job, but grill maintenance that should be done every spring. When the burners get caked is when it's really fun and you need to remove them and clean out the holes with toothpicks. Jenn Air makes quality products, but being a BBQ and outdoors, it's just as vulnerable as any other to elemental and use issues. One last thing to check, some regulators (the disk shaped part right where the hose attaches to the tank) have another air mixture intake there with a screen on one side. Make sure there's no water in it and the opening is face down if you have one like that. Otherwise it's restricting the flow of the propane. I haven't seen one of these in a while, but they're still out there so check it too.
Posted on Jun 10, 2009
  • 2600 Answers
SOURCE: Weber Genesis Gas Grill won't heat up very high
yes the control knobs are what controls the heat, its a saftey thing on the bbq so turn off tank undo gas from tank open knobs release gas from line , turn off control knobs , reconnect gas line to tank ,turn on slowly , turn control knobs to on and light,
Posted on Jul 05, 2010
Testimonial: "Thanks, it worked!"
kjhbwertg65433
SOURCE: Replacement parts for George Foreman Grill GGR50B
Hi, you can purchase on amazon . Amazon com George Foreman Grill parts. If can't find exact part, contact any vendor (probably someone can provide parts) Hope this was helpful.
Posted on Nov 23, 2014
Please tell me I can still find a regulator for a Thermos grill2go grill
gas regulators can be obtained from any gas shop or BBQ shops
the regulator for the unit will be made by a regulator maker and will not need to be genuine
Sep 27, 2015 | Thermos Grilling
How do I replace ignitor switch in thermos gas grill, if this is what is what I saw?
If that white is ceramic, I think it is the actual ignitor, not the switch.
Apr 29, 2017 | Thermos Stainless Steel Gas Grill
Queries to Ask When buy Electric BBQ's
Here are few Queries that You Should Ask While Buy Electric BBQ's
Queries regarding taste
Queries regarding wiring
Queries regarding heat
Queries regarding balcony usage
Read All in Details
Content Resource: http://flueless-fireplace-fuel-store.blogspot.in/2012/10/queries-electric-bbq-buyers-raise-while.html
Thanks
Oct 20, 2012 | George Foreman Bbq Barbecue Grill Electric...
I need a regulator valve for a thermos grill2go bbq model number UK-467638503,PART NUMBER 4158176
I bought this to replace the regulator I lost for my Thermos Grill2Go. Little modification to the grill and it worked like a champ. Portable Propane Table Top Regulator 1 by 20 Female Throwaway Cylinder...
Jul 29, 2011 | Thermos Grill2Go Gas Grill 4656110
Not enough flame and when i change the settings
it sounds like the reg off the gas bottle or blocked burner
May 15, 2010 | Thermos Grill2Go Gas Grill 4656110
Change the igniter on a thermos bbq
You may not have to change the igniter. It works like a spark plug (passing a small spark from an electrode (a small wire sticking from the bottom of the ceramic tube at the lower end of the igniter) to a metal plate positioned close to the tip. If the plate gets covered with soot or grease from cooking it won't work. Try cleaning the plate and bending it closer to the igniter tip. If the igniter is really bad and needs replacement, you can get a new one at most hardware stores. Installation is very easy.
Apr 22, 2010 | Thermos Stainless Steel Gas Grill
Need a catcher for the fat off of the bbq grill
Go on line to Thermos grills and you should be able to order one there.
Apr 12, 2010 | Thermos Grill2Go Gas Grill 4656110
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
