Question about Dishwashers
I have a ED12GW/ED12GS dishwasher and the E4 error shows up. Whats wrong
SOURCE: E4 error on new conia dishwasher
I have a Maytag MJD3000AAW dishwasher and it was showing E4 during a cycle. On checking the pressure tube from the outlet of the dishwasher to the nozzle on the u tube under the sink, I fould that the dishwasher was not draining properly as a kink have developed in the tube where it curved back to the nozzle. I slid the pressure tube into a long elbow which stopped the tube from pinching. Problem solved.
Posted on Nov 02, 2008
whytfang
  • 170 Answers
SOURCE: E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Posted on May 19, 2009
Daniel S
  • 4323 Answers
SOURCE: dishwasher model cdw0302 showing error
Hi
The washer is unable to drain all the water and its displaying error code E4. Excess inlet water is causing this, Error E4 means washer not able to drain. The inlet valves are faulty as they are not closing, make sure the connections to the water inlet valves are fine. If connections looks ok then you would need to replace the water inlet/fill valve. To resolve the issue temporarily turn off the water to the washer after 5-6 minutes and try checking if the error code still appears. If it still appears then tilt dishwasher back 45 degrees and tip out all excess water. You can use some towels, also check the little nozzle on the elbow under your sink where your overflow attaches is drilled out. Restart the dishwasher and check again. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 13, 2011
  • 3247 Answers
SOURCE: my necht wqp12-9319 dishwasher is showing an error
Most likely the flood switch has tripped. This means there could be water leak in the dishwasher.
Pull the dishwasher out after turning off the power and water connections and tilt from side to side.
Wait a little and try and run again. If this fixes the problem then you have to find the source of the leak. Mostly a door seal problem which causes water to get to the motor chamber.
Posted on Jun 17, 2011
  • 298 Answers
SOURCE: Showing error code E4
check for waterleaks filling the overflow tray at the bottom of dish washer that is activating the float switch. check for defects or damage at bottom of dishwasher.
Posted on Feb 01, 2012
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4. I press the program button, i select the washing program i want, but on the display the error code "E4" is being blinking. How do I fix it please?
The E4 Dishwasher Error. According to the manufacturer the E4 error will be given if the vent for overflow when water level exceeds the set level overflow water triggers the lower float, terminates operation and gives E4 warning.
Clean the level sensors.
E4 error showing on a kelvinator kd14ss
good day
my dishwasher give e3 and e4. what is the problem and how can we solve the problem.
Nov 04, 2012 | Kelvinator Dishwashers
We have a belini dishwasher with E4 error code what shuld we do?
Hi, there is a few things that can cause the e4 code......
overdosing the machine can cause excessive foaming.adding soda crystals can also cause this (by clogging) or water pressure is to high.
turn off machine then tilt it backwards about 45 degrees (so it does not upset the water management system) and the water should drain away solving the error code.Hope this helps
Sep 22, 2012 | Office Equipment & Supplies
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
May 31, 2011 | Kenwood Dishwashers
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Had the same problem. First you will need to tilt dishwasher back 45 degrees and tip out all excess water. A couple of towels on the floor are a good idea.
Second check that the little nozzle on the elbow under your sink where your overflow attaches is drilled out.
This fixed my problem after fussing around for a day and I was starting to disconnect everything to take it back.
Sep 15, 2007 | Dishwashers
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
