Cycle won't finish and can't open door - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump
Posted on Apr 19, 2015
SOURCE: Door locked
After trying all the above, making sure that as much of the water has been removed as possible, you can always use the manual door release. This is located behind the soap powder tray.
Push to open as you would normally when adding more soap powder, pull the tray out as far as you can.
Press down on the yellow portion in the tray and this should enable you to then pull the soap tray completely out.
Once out you should see what looks like a small grey plastic circle with a rectangular hole (ideal for a screwdriver) turn this and your door should open.
Posted on Jun 22, 2008
GodBlessU
  • 3513 Answers
SOURCE: door won't open at end of cycle
Thank You for contacting Fixya.com
The most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
also worth checking the spring inside the door lock mechanism attatched to the door, as these can become dislodged.
To open the door you will either require an engineer as the repair necesitates the removal of the lid. The engineer will ensure the machine is disconnected from mains of course. He will double check power is off before reaching down inside the machine to press over the door latch, which is just visible as a white pointed object, poking through the door mechanism. The engineer will push it towards the door seal.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Have a nice day.
GodBlessU
Posted on Sep 12, 2009
  • 104 Answers
SOURCE: Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
Posted on Jan 28, 2010
  • 6277 Answers
SOURCE: I have the BOSCH Maxx
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 01, 2011
caroldon
  • 17130 Answers
SOURCE: my servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Posted on Jul 04, 2012
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Electrolus front load washer door won't open
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Nov 20, 2012 | Electrolux Eiflw55hiw Front Load Washer...
My servis m6011 5kg washing machine door won't
Jul 03, 2012 | Washing Machines
It keeps starting at the beginning of a cycle, won't finish, and can't open the door
1) YOU MUST test the TIMER for defective, test the contacts dirty, or oxide.Loose wire, or open or break.
see the diagram
2)see if the screen is clogged+ test the defective water inlet valve see how to test.
Jun 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Door will not open on my WM1480FHD after wash
Hi ii_goldie,What about the RINSE cycle... maybe the washer knows the "full cycle" is NOT finished.
The washer will display DONE... and make the door available to you. If not the cycle may not be finished. OR, turn it off, however, DON'T open the door if your machine has not drained all the water out, allow the system to finish.
Aug 19, 2009 | LG Washing Machines
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
