What does esp mean on a loungry Matt washing machine
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Mar 11, 2017 | Electrolux Washing Machines
Wat does esp mean in the right hand corner of the screen
if you are on Windows machine, the Esp or any text in the lower right corner of the screen indicates the "Typing Language" or "Input Language" of your machine (Computer), in this case your input language is Espanol (Spanish Language)...
Mar 04, 2016 | Computers & Internet
How do I change the bearing in my machine?
How to Replace Washing Machine Bearings - YouTube
? 17:40
www.youtube.com/watch?v=XaFF2-Rl8Nc
Feb 23, 2011 - Uploaded by eSpares For all your washing machine spare parts go to http://bit.ly/5ET67ij In this video, Matt replaces the drum bearingson a Bosch washing machine. ... Well, I was gonna have a look at mine, but although not beyond my ability, ...
Sep 28, 2015 | Washing Machines
How do i remove the loc code
I appreciate your post, friend!
Based off the information you have provided you are receiving a "LOC" code on your Frigidaire washer. "LOC" typically means that your control lock feature is on to remove the lock feature you need to hold down the options and select buttons for ten seconds. I hope this is helpful. -Matt
Feb 17, 2015 | Frigidaire ATF6000ES Front Load Washer
How do I undo a paper jam
of course as cafefully as possible
Jan 28, 2015 | Kodak ESP 7 All-in-One Printer
On kodak esp 1.2 is there a head cleaning switch, as printer worked 3 weeks ago asked for ink, which has been done but now saying no ink
check your print head it is stopeed up, remove it and clean with water just the jets, or use qtips, plain water no chemicals, Matt
Jan 16, 2015 | Kodak Esp 1.2 All-In-One Printer
I have a Frigidaire front loader washer model number LTF7000EGO and it was washing fine then started a beeping noise with dr flashing. What does that mean?
Hello friend, thank you for your post!
I understand that your Frigidaire washer, LTF7000EG0, is displaying a "DR" error code. "DR" stands for door which means a problem with your door it could be an issue with the door latch assembly or door strike. I would suggest resetting your washer and you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes.
If you continue to experience an issue with the error code "DR" I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
Oct 09, 2014 | Washing Machines
E20 Error
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
I have an Affinity washing machine that shows an E23 error code.
Hello Robert Reische, thank you for your inquiry!
I understand that your Frigidaire washer is showing an "E23" error code. Based off the information I show "E23" stands for drain pump relay on board failed or wire off the pump. Which means you could have an issue within the main control board or wiring to pump. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance. Hopefully this helps. -Matt
Sep 11, 2014 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
