Question about Dome 4 CCD CCTV Camera Surveillance Security System with Stand Alone DVR 250GB Supply free surveillance DeCal DVK2501 1BH
How to install cctv ip cameras with dvr - Dome 4 CCD CCTV Camera Surveillance Security System with Stand Alone DVR 250GB Supply free surveillance DeCal DVK2501 1BH
My CCTV is showing hacked on the cameras. How do I reset my password
Your CCTV is connected via an Internet connection.
I'll recommend to isolate the network devices from the Internet before continuing.
This is covering only basic steps, I recommend to get the instruction manual for the CCTV and read it.
  1. Enter the administration section of the CCTV recorder/DCR/NVR by entering your admin account name and password.
  2. Go to the admin setup of the CCTV. Search for overlay and verify if the hacker inserted text on the overlay feature, if you don't use overlay, disable it.
  3. Then check each camera name tags in the admin section. Change the text if it was hacked.
  4. Change the password for the CCTV DVR/NVR/Camera, I bet it was never changed. Write the password down and store it in a safe place.
  5. Last option: If you can't find the place do a factory reset of the DVR/NVR/Camera. (Do make a backup before a factory reset to an external device if possible).
  6. Once the factory reset is done, you will have to reconfigure the recording options for each camera.
  7. Last point after the factory reset, change the admin password.
Are there other devices sharing the Internet connection with the CCTV?
If this answer is YES, then check them for hacker breach.
  1. I'll recommend to increase the security on the Internet Router.
  2. Any device sharing the Internet with the CCTV should be checked for breaches and made secure.
  3. Speak to your ISP and ask for assistance if you have a fixed IP address to your CCTV system. Ask them for advice. Layer 7 routers are more expensive but more secure.
  4. Load all updates for any devices!
Get an IT security expert to assist you with the breach if necessary.
Sep 29, 2017 | The Home Security
CCTV DVR RECORDER
Have one did the same, tried to boot up when powered up, then started beeping. Found bad hard drive, replaced all ok.
Feb 23, 2014 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
Cctv
Use Free DDNS Services
Create Free account.
Visit:- https://www.noip.com/ CCTV Networking Technical Support
Dec 25, 2013 | Digimerge H264 16 CHANNEL DVR WITH USB CMS...
Will not connect with my pc
I would recommend you to install the Software of the DVR System properly.
The System is provided with the installation CD. Only matter when such DVR'S are needed for the cctv camera with ir illuminators.
Follow the steps:
1) Insert the mini CD into a CD/DVD ROM drive on your computer.
2) If your CD/DVD ROM drive does not auto run the CD; click MY COMPUTER click on the drive the CD is in and double click on the "D9-VIEWER-DBG-ENG.EXE" file.
This will definitely help you.
Sep 26, 2013 | Swann Communications 2500 8 Channel DVR...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
No picture on my tv from cctv camera
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
May 24, 2009 | Sharp Cameras
Cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
Sep 19, 2008 | Computers & Internet
CCTV NETWORKING INTERNET
Best results are to use a Netopia WiFi Business Router for a DVR installation. A Siemans modems will drop the CCTV connection at random and you will have to restart the DVR manually...which defeats the purpose of having constant video being remotely accessed. We are switching to Netopia to solve our problem with AT&T and Siemans.
Dec 09, 2007 | Computers & Internet
Dome 4  CCD CCTV Camera Surveillance Security System with Stand Alone DVR 250GB Supply free surveillance DeCal DVK2501 1BH Logo
62 people viewed this question
Top Dome Home Security Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Dome Home Security Expert? Answer questions, earn points and help others
