AFTER SWITCH ON, AC DISPLAY IS SEEN.BUT,FAN IS NOT SPINNING......
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 83 Answers
Check the breakers and fuses and reset the power , try the fan only and see if the fan comes on, if not please include make, model# and serial # of the unit.
Posted on Apr 07, 2015
Turn on AC but outside unit fan doesn't move
Either a very bad Capacitor, or the fan belt came loose and the motor is just spinning
May 26, 2014 | Empire DV-215 Direct Vent Natural Gas...
Ir 2020 e805
E805- Fan Failure- open rear cover find PSU and check for rotation of cooling fan at power up ( spins as soon as display lights up)
If it isnt spinning - replace with correct part from Canon, the circuit is expecting a feed back specific value which will only be seen with the correct fan.
Jan 16, 2014 | Office Equipment & Supplies
I have a Grand Vitara Suzuki 2008. Aircondition stop generating cool air. what could be the reason. car has 14,000 km and since last check I have travelled 1000 km
AC dead. all the time? truly all times.
1: does the fan blow? full speed.
2: does AC work on a hot day and a cold started engine? y/n
3: did you check the freon pressure, with the cheap refill kit
that has a gauge with the kit and hose.
is the gunge reading zero?
4: you start engine, and open hood and look at the AC compressor.
is the fan belt to that compressor turning, or is the belt missing.
if turning is the AC pulley spinning, that is not just the pulley but the
compressor front part and its main shaft, are they spinning.?
if not the AC clutch is disengaged.
if disEngaged, that means the AC logic box, is not happy.
The AC logic box can shut down the AC for 4 or more reasons.
and to find that , I stop here.
the fsm shows the pins on the logic box to see with logic input is failing.
on my car, its:
1: A/C on , switch is off.
2: fan not on, or power to it dead, no fan the logic cuts the compressor so the core dont freeze up and crack.
3: engine overload
4: engine overheat.
5: freon pressure too high.
6: freon pressure too low.
7: too cold outside, so shuts down , has to be extreme cold, RTM.
at the least. all this logic functions, save fuel and save other parts
from damage. and huge costs.
that is it for today, one more unsolved.
Aug 05, 2013 | 2008 Suzuki Grand Vitara
Ac only works on low
correct my did the same thing replace the switch
May 29, 2012 | 2007 Mitsubishi Eclipse SE
What will stop the fan to stop spinning on a goodman ac unit on the outside
If you are wanting to just get it to cut off because it won't do it on it's own, you can turn the a/c breaker off at the breaker box. I have seen alot of blower fan switches go out on older goodman units and the blower stays running all of the time. Get a technician to check it for you. Good luck .
Jun 18, 2011 | Heating & Cooling
I have a c200 1996 classic, auto. The front radiator's fan (NOT THE DOUBLE ac FANS) is not spinning fast enough to cool the engine. what is causing the weakness of the radiator's fan spin? I appriciate....
The front fan is a slow spinning ac fan, the rear rad fans are for cooling and also ac at times, if the car is overheating then you may need to check the coolant fan sensor,or the thermostant,
Dec 08, 2010 | 1996 Mercedes-Benz C-Class
My ac fan is spinning counterclockwise resulting in overheating
you need to switch the two wires around for it to spin the other way
Jul 30, 2009 | Heating & Cooling
Carrier AC Model No. 38CKS fan not spinning
You have bad cccccccccapacitor in your outside unit. Not hard to replace but you need to find someone to sell you one It should say 45 5 or 50 5 on the side of the capacitor. You can also call a service tech about 150 for the repair. Rus Carrier Dealer 45 years
Jul 18, 2009 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
