Question about Minolta Office Equipment & Supplies
My Konika Minolta B 211 cant fax, it says No communication but the line is ok. What could be the problem?
  • Minolta Master
  • 6,696 Answers
Is the fax cable plugged into the "Line" connector not the "Tele". Call the line does it ring ? replace the fax cable, bad fax board, sure the line is analog not digital.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on May 22, 2015
Nicolomd
  • 84 Answers
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
Posted on Jan 19, 2008
Kevin Hayes
  • 167 Answers
SOURCE: konika minolta bizhub 350 fax no answer
Try altering the maximum nuber of rings until it relays the no answer message.
I am not sure exactly where that is.
ALso, you could try turing on the phone line volume so you can listen to what is heppening.
Posted on Sep 22, 2008
Bubbabear64
  • 2794 Answers
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Posted on Nov 07, 2008
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
  • 220 Answers
SOURCE: 2 vertical lines on Konika Minolta 2340DL
the laser scanner assy is faulty.
Posted on Jun 30, 2009
I have a Konika Minolta bizhub 211, If I want to photocopy with it, it is pouring some ink on the paper as it is printing. so what can be the solution to this problem please. I need an answer
It's possible to be warn developer (i need to know how many copies are developer) or image unit is leaking. If i see a paper printed by the copier, i can do more accurate answer. You can call a service center.
May 01, 2018 | Minolta Office Equipment & Supplies
Error code com 0001
Hi-
Go to fax settings and try turning off the ECM, if its off then switch it on, chances are its a communication error on the line. Keep me posted for further errors.
Have a nice day!!
Jun 11, 2008 | Office Equipment & Supplies
I have a konika minolta bizhub c451, im trying to print but the image is coming out blank, how can i resolve this
Does the machine copy OK does the machine print out counter page and demo page ok?
Apr 12, 2016 | Minolta Office Equipment & Supplies
Why cant I send a fax
I share a informative links please visit and check it your error options.
Read More... Cannot send fax using all in one printer and Interpreting Error Codes in Fax Communication Error or Fax History... and If any more Help.. HP Printer Support
Thanks,
Sep 08, 2014 | Office Equipment & Supplies
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
VERTICAL LINES ON KONIKA 2400
If the line is white (no toner is added in that area) check the laser head glass which is located right below the drum. Remove the drum and you should see it below a narrow strip of glass. Just be sure to be clean, with no dirt, toner or pieces of paper on it.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 22, 2008 | Konica Minolta magicolor 2400 Laser...
Konika minolta bizhub 350 fax no answer
Sep 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
