I need a needle for my Thomas millennium series record player model number is TPC-2001 DONT KNOW WHICH ONE I NEED OR WHERE I CAN BUY ONE.
    Sergeant:
  • 357 Answers
EBay item number 221388304031 should do it
Posted on Feb 23, 2016
  • 10 Answers
SOURCE: Needle and manual for Electrohome 711 ''Saturn'' record player
HI THIS COMPANY DOES REPAIRS ON YOUR MODEL GIVE THEM A RING OR EMAIL THEY SHOULD BE ABLE TO GIVE YOU ALL THE HELP YOU NEED
DEREK
http://www.nyco-systems.com/Products/mfr.php?mfg=1880
Posted on Nov 30, 2008
  • 42 Answers
SOURCE: Need new needle casing and needle for record player part of this
I would suggest that you look at the MUSONIC web-site. They specialise in cartridges and styli and will answer any questions by e-mail.
Posted on Jan 25, 2009
  • 4234 Answers
SOURCE: I bought a very nice toshiba record player arm won't move
I am not familiar with that particular model, but the hum is probably the motor. I would check to see if the belt has slipped off or even exists. I'll look it up tonight and update this if I find out more.
Dan
Posted on Sep 10, 2009
lesliemurphy
  • 69 Answers
SOURCE: I need a new needle for my Garrard 40B turntable
contact this company and ask them if they have the correct replacement or a suitable equivalent?
mailto:info@needledoctor.com
Posted on Oct 07, 2009
  • 3 Answers
SOURCE: Thomas Pacconi Model TPC-MSE-800 turntable
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Posted on Jan 21, 2011
I have a Thomas Pacconi Model TPC-MSE-807 turntable. The Power/Volume Control has gone on it.
Look on the data plate to see if there is a voltage and current draw value on it. The switch should be rated at 120 Vac @ 10 A.
Feb 02, 2017 | Dual Audio Players & Recorders
I need a needle for thomas pacconi phonograph model tpc-hd-12 can you help?
What you do is look at the cartridge it fits in, then note down the make and model number and enter that into Google. The stylus should then show up.
May 30, 2016 | Audio Players & Recorders
How to change needle on record player
The "needle" should be connected to the record player in a simple fashion, just inserted into a slot. First see if you can remove the existing "cartridge" (the entire part that includesd the needle) and then look online for a replacement that looks the same, or search according to the turntable model number. There are many different types of cartridges, so you need to know what to buy. Here is a link to show man of the possibilities: https://www.google.com/search?q=turntable+cartridges&source=lnms&tbm=isch&sa=X&ei=aoHfVPXhN8PZoATI3YIY&ved=0CAkQ_AUoAg&biw=1920&bih=952
Search google with the model number of your turntable, and then the word "cartridge"
Feb 11, 2015 | Crosley CR711-BK AutoRama Retro Turntable...
I have Thomas Pacconi 3-speed phonograph model TPC-7475 and wanted to attach external bookshelf speakers. Is there any way to hook speakers up to the line out jacks?
You need to buy the Jack's male plugs, Wal-Mart has them if memory serves, and splice your speaker wires onto them, preferably with a soldering gun and heat shrink insulation.
Jan 12, 2015 | Seth Thomas Pacconi Turntable
My museum thomas series record player runs slightly too slow. How can I fix this??
Try changing the needle which runs on the record this is to do with clarity , makes a big difference and you get many types of needles
Dec 29, 2013 | Seth Thomas Pacconi Turntable
I recently received a Viking Solid State Record Player. and I need to buy a needle/cartiridge for it but I dont know WHERE to buy it or WHICH NEEDLE to buy! This is the Model: N 2 SFG 249
You always go on the installed cartridge for any deck when finding the correct stylus (not called needles now). It should have a model number on it, put that into Google and you should find the stylus. You can always fit a new cartridge and stylus. It's just a question of which one will fit into the headshell. That way you can get better sound.
Aug 27, 2013 | Audio Players & Recorders
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
May 15, 2012 | Audio Players & Recorders
258 people viewed this question
 Grubhead
Grubhead
